Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My macbook wont start up sucessfully. Once i boot it up it loads up to the gray apply and spins and continues to the blue backround. But other than that it wont go any further. I tried to get it into safe mode but it still isnt working. Anyone can help me with this?
    Scholar:
  • 72 Answers
If safe boot doesn't work, follow the steps in this article:
http://support.apple.com/kb/TS2570
Worst case scenario you'd need to do an Archive and Install (see how in http://support.apple.com/kb/ht1710) if you're running 10.4 or 10.5, or in 10.6 you can just reinstall the system without having to do anything special.
Posted on Jul 08, 2010
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
How do you resest pram
I would try starting the machine up in single user mode you do this by booting your machine up and then immediately press and hold the command (Apple) key and the s key. If you do not know how to reboot press down the command-control-power key at the same time.
Once you get white text appearing on a black background at the command line prompt type /sbin/fsck -fy then press return. The machine will then go through some testing and then hopefully it will tell you that your hard drive is okay. If it says that the file system has been modified run the comand again i.e. /sbin/fsck -fy When the fsck command reports that your hard drive is okay type reboot at the prompt and then press return. Hopefully your computer will boot up okay after this.
Nov 12, 2011 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
My macbook wont fully load up it just turns on to a blue screen and nothing happens the motor stops and its just frozen and i would like to know how to fix this problem and get away from the blue screen of...
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Jan 07, 2011 | Apple MacBook Pro Notebook
My Macbook told me that I had to shut it down while I was working, which I did. Now when I try to turn it back on all that comes up is a small folder in the middle of a blank screen that changes between a...
Thanks for contacting Fixya Support, I am glad to assist.
What you need to do is perform an SMC Reset in order to allow your Macbook to start back up correctly to the desktop.
Here are the procedures for an SMC Reset:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the Macbook's
battery.
• Press and hold the power button for 5 seconds and then
release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the Macbook
If this does not work, then try this procedure:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps.
Regards,
-Mactechtrainer
Sep 16, 2010 | Apple MacBook Laptop Computer Mac...
MacBook Air. On start up, system tells me that the hard disk is full. Then hangs, with a blue screen. I get the shut down etc dialogue box, but that's all. Are there any start-up options to get...
Thank you for contacting Fixya Support.
Try these steps:
- - Reboot your Mac
- - Upon restarting your Mac, press the Shift key.
- - Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
- - When you see the Spinning gear, release the Shift key.
- - Allow the Mac to continue booting up. Also this may take a little while
- - You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
- - Once within the Desktop in Safe Mode
- - From the Finder Menu, click Go> Go to Folder
- - Type in this line: /System/Library/StartupItems
- - This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
- - Remove all of those folders to the Trash.
This should help.
Regards,
-Mactechtrainer
Sep 02, 2010 | Apple MacBook Pro Notebook
Once I put in the password the desktop does not
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
Thanks!
Regards,
Mactechtrainer
May 06, 2010 | Apple MacBook Mac Notebook
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Mac book only shows apple logo when turned on
This could be an issue where you may have a few Startup items in your StartupItems folder in your System Library which may be affecting your Macbook's startup.
So I recommend you boot your Mac into Safe Mode to see if you can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
Let me know if this helps!
Regards,
-Mactechtrainer
Jan 28, 2010 | Apple MacBook Pro Laptop Computer with...
Have an hp pavillion a6319fh boots to blue screen and curser
Could be alot of things, Scratched , even a small pinprick on the CD, or you have some bad ram, or your Hard drive is going. Thats the thing about troubleshooting a PC.
Sep 22, 2009 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
145 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
