My Trane heat pump makes whistle noise at the reversing valve. My HVAC tech says it could be a sticking valve or a bad txv any ideas
Did you ever get a solution? I have the same problem. My tech also says it is the txv.
Posted on Nov 04, 2010
Where do I find my reverse valve
Mogamad
A reversing valve a type of valve and is a component in a heat pump, that changes the direction of refrigerant flow. By reversing the flow of refrigerant, the heat pump refrigeration cycle is changed from cooling to heating or vice versa.
make and model would help along with detailed question.
RE POST WITH INFO
Diagnosing the stuck HVAC reversing valve
Jan 29, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Where do i find the expansion valve on a 3.5 ton trane air handler. Model no of the trane air handler is: 2TEC3F42C1000AA
The TXV (thermostatic expansion valve) is always at the end of the high pressure liquid line as it enters the evaporator. This is the small line. The outlet of the TXV will usually have 4, 6 or 8 smaller lines feeding proportional portions of the evaporator coil. You have to remove the cover of the evaporator to access it.
Some units do not use a TXV, so you may have a 'fixed restrictor' instead. It too is located where above described.
Apr 28, 2015 | Heating & Cooling
Ruud heatpump mod uprl024jez ser 7220m280813390 in heat mode 15 degree ambient 70 degree in house low side 55 high side starts out 250 steady climbs to out of sight r 410 reverse to cool low...
Remove bulb and warm with hand. Watch pressures to determine if txv is functioning. I do believe there is something out now that will free a stuck r.v.. Have not tried this but inexpensive start. At 15 degrees you're liking using heat strips, possibly machine trying to do both. Good Luck
Mar 19, 2017 | Ruud Heating & Cooling
The unit makes a noise. sounds like a pressure relief when the unit shuts off
If this is a heat pump when the unit shuts down it de-energizes the reversing valve causing it to shift and make a loud swishing noise, which equalizes the pressures causing that sound.
If it's an air conditioner you are probably hearing a pressure flow thru an orifice or a txv opening.
Jun 29, 2010 | Heating & Cooling
Air conditioner squeals when air turns on but not when heater turns on new 2 yrs.
Assuming this is a heat pump, more than likley the reversing valve is either going bad or there is a restriction in reversing valve. Regardless of what type of unit this is the parts are under warranty. Call a good Hvac tech to check out system.
Mar 28, 2010 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
775 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
