Question about Microwave Ovens
Why does my iron get hot but does not steam anymore?
  • Microwave Ovens Master
  • 6,826 Answers
Minerals can get lodged in the passages if distilled water is not used.
Posted on Jul 08, 2010
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
My iron is squirting out brown gunk from the steam holes under the iron itself. i have cleaned and rinsed it out. the manual says it is a gc 7430, gc7420.
Sometimes using vinegar and water will clean out your steam iron - but smells really bad. Usually the brown gunk is a sign that there is corrosion so even if the vinergar works, you should plan on buying a new iron in the near future.
Jun 22, 2011 | Microwave Ovens
My elitech steam generator iron does not make any steam it works as an normal iron but to press the button for steam there is none???
there are 2 controls to make the steam. a dial on the base which must be turned. Then the temp must be above silk and nylon and then when you press the button you will get steam. You must have bothe the dail and the button. One without the other will not make steam. Obviously you need water too
Apr 27, 2011 | Elite Microwave Ovens
I HAVE A ROWENTA STEAM GENERATOR IRON AND IT IS ALWAYS SPITTING OUT WATER WHICH STAINS MY FABRIC. i AM A QUILTER AND USE THE IRON ALOT.
Drain the water if don't need steam function, that's the best thing you need to do. Some iron when there is water like the one you use, when if its full on water really split out water, keep water in minimum or drain all of it.
I hope my advise help you.
Mar 29, 2011 | Microwave Ovens
I have a polti steam iron 600 do i have to use distiilled water or will tap water be ok thanks
Steam irons are built to run on tap water, there will not be any problems whatsoever unless the water is hard, which may leave sediments inside the iron after evaporation.
Feb 28, 2011 | Microwave Ovens
How do I add water to the pressa bella dry steam iron
Turn the big yellow top, if it's air tight use a plier and gently turn it. That will the trick.
WARNING!!! Becareful not to over fill the water reservoir by doing so the water boils making it leak. It is extremely dangerously as I steam burned my hand. Other than that u won't have a problem.
Jan 18, 2011 | Microwave Ovens
What descaler can i use for my russell hobbs slipstream 14862
The cheapest and most environmentaly friendly de scaler is spirit vinegar otherwise known as white vinegar.
Pour some in the tank and let the iron get hot.
Steam on some old cloth a few times and then when it is clean, refil with de ionized water and flush through a few times.
Hope this helps.
Nov 29, 2010 | Microwave Ovens
I have a steam station Iron, it stopped sending the steam from the base into the iron through the cord .Also it has debris in the base when i empty the water Do you know the problem & can you offer...
This can be checked by you as there is not much of mechanics . Make sure that the steam is generated in good quantity so that the cord gets full pressure, if not clean the base perfectly so that there is good contact -- no debris .. make sure with a air pressure or water jet the connection tube is clean and not damaged at any points, if so the steam will not flow .
Once this is established you will get good steam pressure or else the connection tubing cord needs a change.Also make sure there are no issues in the iron to block off steam.
Sep 30, 2010 | Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
