Question about Brother IntelliFax-4100e Fax
Getting thick black line on edge of paper on all faxes coming thru
    Scholar:
  • 50 Answers
If it is just on faxes you are receiving and not on ones you send it sounds like it may be your drum. You may have a small tool in the fax to gently rub across it and clean it. check your manual to make sure. In worst case scenario you will have to get a new drum. Look on line for your model. Other wise if it's on copies and faxes you send as well it's going to be the thin piece of glass right where the pages are being feed in that needs to be cleaned
Posted on Jul 08, 2010
Thick lines
Check the fusing unit and or transfer belt. Does it print OK not copy! Print Ok means internal OK then check the scanner section
Nov 11, 2013 | Minolta MF1600E Plain Paper Laser Fax
Tip
Black lines when sending faxes or making copies
I've been getting many calls asking me why their fax/copiers/printers are getting black lines when they send faxes and making copies while using the automatic document feeder, and not when they open the document feeder and use the glass.
What happens, when you fax or copy papers that has white-out or some material that can flake off, it gets embedded on the ADF glass and the unit thinks its part of the paper.
99% of the time, what needs to be done is to clean the small glass, usually using fingernails to scratch off the dirt, or using a lint free cloth slightly moistened, should do the trick. Just go over it several times until it comes off.
If the lines are thick, it usually indicates a damaged scanner assembly, in cases with the Brother machines, not expensive to fix. With other units, its a different story, either because they do not sell the scanner assembly as a part, or units are sent in for whole unit repairs.
on Jun 08, 2010 | Office Equipment & Supplies
Solid lines varying in with
When you copy? or when you print? If print OK check the doc feeder
I'M GETTING A THICK BLACK LINE DOWN THE MIDDLE OF MY. PHOTO AND UPLOAD. TRIED RE CALIBRATING WITH WHITE PAPER. DIDN'T WORK HELP
What printer do you have? Is the black line appearing on the paper when you print or when you fax/copy something?
If it is the latter, then there will be a mark on the optics glass that needs to be cleaned. Usually people using whiteout when wet causes this.
You will need to lift the cover where the paper goes through and check the glass
May 20, 2011 | Office Equipment & Supplies
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Thick black line down recipeints faxes
Your scanner glass is caked with ink or lint. Open front cover and clean with windex or rubbing alcohol.
Apr 23, 2010 | Brother IntelliFAX 2800 Laser Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines when using copier
Lift up the document feeder and look for wite-out on the small glass.
If there is a sliding blue tab on the toner cartridge, move it back and forth 10 times. (cleans the charge wire)
Physically look at he drum, it should have no toner on it.
Sep 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Brother IntelliFax-4100e Fax Logo
190 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
