Question about Smeg SE250XUK Stainless Steel Electric Single Oven
I have a SMEG S381X Multi function oven and the symbols have been wiped off. Does anyone have a picture of them?
4 Suggested Answers
SOURCE: I have a Smeg oven
Go to www.appliancesuwant.co.uk/acatalog/CookingFunctions.html
Posted on Aug 18, 2008
SOURCE: SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Posted on Oct 05, 2008
venexcsd
  • 1185 Answers
SOURCE: Smeg fan oven not working, all other functions ok
You need to place use a multimeter to check the element for continuity if that is ok then the next step is to check for 240v being
switched to the fan and element array.
With the unit switched off at the wall put the test leads onto the correct points ( Use the earth post for the Black lead) switch the meter to a range to cover the 240vac and then switch on the unit
If there are no readings then you need to go back up the wiring to check the input to the thermostat
Posted on Feb 24, 2010
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
Don't know what the symbols mean
Here is a link for the manual. Page 8 describes what the functions are.
http://www.smegtech.com/site/smeg/pdf_libretti/914773713-GB.pdf
Sep 30, 2009 | Ovens
Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
Aug 31, 2009 | Smeg S1100MFX5 Electric Single Oven
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SA 398X
50
90
120
160
200
230
Hope this helps -
Jane
Jul 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I have a Smeg oven SA708, but all of the symbols on the front of the oven (functions / temperatures) have been wiped off by a previous tennant. Just after a picture or diagram of the front of the oven...
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Apr 13, 2008 | Smeg S1100MFX5 Electric Single Oven
Smeg SA995XR Oven
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Sep 08, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
147 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
