Question about MSI MS-6340 Motherboard
After bios flash, bips & no booting... is it a way ?
    Guru:
  • 200 Answers
Flashing a BIOS is risky, if any little thing goes wrong and it fails to flash properly, you get what they call a "bricked" BIOS. It is highly recommended not to flash the BIOS unless there is a problem with the currents system. I hate to be the bearer of bad news, but once the system has been shut down after a bad flash it's too late to fix it the easy way. Depending on your level of experience you can try to de-solder the old BIOS and solder a new replacement BIOS. Otherwise you should send it to the manufacturer and let them deal with it. Alternatively you can try to find your model motherboard online and replace it.
Posted on Jul 08, 2010
    Problem Solver:
  • 8 Answers
Check your chip. If it is a PLCC 32 pins, you can order one on ebay. Or if there are no 32 pins chip, then it must be 8 pins. You will need someone to re-flash your own chip. www.biosxp.com
Posted on Sep 03, 2010
3 Suggested Answers
  • 156 Answers
SOURCE: I have 1Gb memory in A1 & A2 Power is
check your ram modules and also check if your video cards fans are running right. If both are ok then try clearing the bios it should work out
Posted on Dec 02, 2009
xptareq2000
  • 1447 Answers
SOURCE: COMPUTER ON & BOOT DISPLY THAN DISPLY OFF
May be problem on processor cooler please replace this ,Must be problem solve.
Posted on Mar 11, 2010
Changed bios to set to factory reset with recovery disks
??Why were you messing with the bios?? Has absolutely Nothing to do with a restore!!!1-computersurgeons.com for a restore disc set. 2-Most important part, restore is useless without the correct bios. U R N over your head, but wimsbios.com for bios, flasher & u need a boot disc, hope it has a floppy, otherwise you have to make an iso boot disc with the correct bios & flasher on it(preferrably an cd-rw so it can retrieve bad bips on) good luck...u gonna need it.
Apr 10, 2014 | HP Compaq Presario SR1920NX PC Desktop
Nov 17, 2009 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Corrupt & Locked Bios
When you flash the bios (normally from a floppy drive) it should overwrite anything that is there.
In this case you must boot from the floppy. Unfortunately, with a laptop you don't have that option.
I suggest you put the bios flashing utility that you probably downloaded with your bios update file on a flash drive. I think your laptop has the ability to boot from that.
Anyway, on startup, press F12 until you get the boot options and try that.
I take it that you know the support site URL, but just in case, it's support.dell.com
Nov 12, 2009 | Dell Inspiron 2200 Notebook
Erased bios?
Oh, just try to reseat the RAM module. When not detected even beep code will not sound. Or clean also its edge connector with pencil eraser.
But if you are talking of your flashing your bios. Well that's another story.
Apr 21, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Moniter won't come on
hi
check your ram.put ram away and check your bip is comes on or not .if u get long bip your cpu is ok.and your ram pro.
clean your ram and fix it again.
clean oyur processor case.
clear your bios .
pls take step one by one.
Mar 24, 2008 | AOpen F90JS (Black) 19 in. Flat Panel LCD...
-lost bios will not open on startup pressing DEL -screen is black with small white bar flashing in left top corner -presing F1 or F2 brings up invalid system disk, replace disc & press any key, or...
U do a flasing of ur BIOS, there will a jumper on the mother board, U can find it refering the manual of ur mother board, jst change the jumper to flash the BIOS, then try booting...
Mar 21, 2008 | Computers & Internet
MSI MS-6340 Motherboard Logo
102 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
