Question about Whirlpool LER4634J Electric Dryer
Dryer produces some heat, but not enough to dry a load in one or two cycles. What is wrong?
    Guru:
  • 366 Answers
Make sure your vent screen is clear of lint, You should also check the actual vent duct which comes out the back of the dryer. It sounds like there is blockage of dust and lint which is not allowing the dryer to properly heat up.
Posted on Jul 08, 2010
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Why does The drying process not produce any heat?
If your dryer is electric: need to check for two things: bad over-temp thermostat (open)...or...open heating elements. If gas, check pilot and/or auto firing circuit.
May 13, 2014 | Tecnik TKL9290 Front Load Washer / Dryer
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
Dryer not producing heat!
Dec 18, 2008 | Dryers
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
