Question about Sony PlayStation® 3 Black Console
Ps3 fan goes nuts and message says "too hot must turn off"
Ps3 fan goes nuts and message says ps3 is over heating. i had issues with it before when it started giving 3D black lines within games i was playing. then it started to freeze alot. After the freezing it completely didnt work. I would turn on the ps3 and the screen would be black with yellow lines on the top and bottom. I took it apart, and put new thermal paste on it and now it turns on, but it doesnt run for very long until the fan starts to rev up really fast and gets really loud. i then get a message stating that the ps3 is very hot and needs to turn off in which it turns itself off.
SOURCE: Ps3 freezes after start up
i had the same prob but i fixed it. i had the wavy line that froze right when i started the playstation. but i miraculously fixed it by plugging in the controller to the system, turning on the controller and turning on the playstation by holding the power button after it beeps once, keep holding it until you hear a double beep. then a menu should pop up. click the rebuild hard disk. then it will turn off then do everything again to get to the menu and click restart system on bottom. then it should be fixed
Posted on Jan 28, 2009
  • 42 Answers
SOURCE: ps3 freezing and wont load after it freezes
If you press the PS button does it bring up the XMB? If it does that means your bluray laser is dying. They are about $70 on ebay and you can replace them using the guide here: http://progamer.cc/blog/ps3-laser-kem-400a/how-to-replace-a-ps3-bluray-lens-guide.html/ another option is to send to Sony and for $150 (if it's out of warranty) they will replace it.
Posted on Feb 12, 2009
rulds2008
  • 3866 Answers
SOURCE: PS3 FREEZING
This is due to fulty caps inside.. This will need to be looked at buy a autherized Sony repair technition.. If its under wareenty it will be covered and the unti will be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 20, 2009
  • 5 Answers
SOURCE: My Ps3 doesn't recognize my disc
Pretty sure its your laser, mine was doing the same thing, you might need to clean it before replacing it though. If you do need to replace it, the part runs at about 70 usd.
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: when i put a game in my ps3 it reads the disk then
is the disk scratched
Posted on Nov 14, 2009
Ok, so i had a YLOD issue. Went through step by step with the common repair. Stripped it down to individual components, cleaning each as I went. Used the heat gun technique and followed the instructions to...
Hello , there is a thermostat in the unit and quite often when i do the ps3 or xbox reheat and assemble and test too quickly its still too hot on the ic and goes into protect mode.Try it again now that its cooled down.
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
My ps3 reads system is to hot and shuts down within five minutes. I don't think the fan is working at all. No warranty how can I fix this myself? I know how to take ps3 apart and I've cleaned the dust out...
Try upgrading the firmware as well.. Or doing a factory reset..
The error code could simply be stuck, and an upgrade or system restore may fix the issue if you have already cleaned the fans.
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on and then right back off.,
It sounds like a power/temp issue. Make sure your PS3 is in a very well ventilated area to keep heat from trapping itself and over-heating your player. Air-Cust your PS3's vents/fans/and other openings. If still doesn't work, I would call customer support.
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Gets real hot
Sounds like a fan died inside, needs to be serviced by Sony, they should do it for free. Google for Sony PS3 Customer Service phone number.
Jun 26, 2009 | Sony Playstation 3 (PS3) Console
Fan isn't spinning and cooling the unit anymore.
This means that you ps3 is deffected. It can also mean that your ps3 is not getting good ventiltion if it is in a cabnet move out of there and make sure that no vent is close to a wall be 1.5 feet this will cost you ps3 to heat up. If that dosnt work than your fan isnt working properly call 1 800 345 7669 that is sonys number call and see what they can do
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 crazy fan problem
Its a power supply issue you might want to exchange the PS3 for a new 1 at www.sony.com
Rate my Solution Please
I tried my best.
Apr 30, 2008 | Sony Playstation 3 (PS3) Console
Don't even know
If you try reseting the unit unplugging everything and plugging back in.
Also , did you receive the 1 year warranty with your unit. I would call Sony and push for a new unit.
It seems like alot of people of having the same issues with their unit also.
"Good Luck"
Apr 29, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 overheating Fan problem?
I have done the research!!! And I wrote this guide taking more safety precautions against breaking my system than the originators so this is a reproduced guide wearing safety belts.
This means there are 2 possible problems with your PS3. Either 1) your fan is dying and needs to be replaced or 2) the heat transfer from your 2 processors to the fan is deteriorating. Number 2 is the most popular for overheating because Sony didn't use the greatest of thermal compounds on their processors, and the heat sink solutions Sony used in its launch systems weren't as well engineered as the later systems. 60gig are the most prone.
This has happened to me and I have fixed my PS3. It works perfectly as if I had just bought a new one (fan is super quiet, showing that the heat transfer is working perfectly) and 5 months later I had to repeat the process and it fixed the problem again. So, this solution may have to be an ongoing task through the years, I suggest doing it 3 times a year like I plan on doing. All you need is a couple screwdrivers, thermal paste (preferably something with silver or more expensive, Arctic Silver is good), and a heat gun (usually made for stripping paint) that gets to at least 650F. The processors in this MB are soldered in...
Okay, assuming you are good with handling hardware and get the PS3 bare down to its motherboard, you should see the huge *** fans mounted to the 2 processors, 1 says GPX and the other CELL I think.
1- You need to take off the fan carefully 2- Clean all the dust you can possible see, CAREFULLY 3- Use acetone or some other 99% alcohol compound to clean the old thermal paste off the back of the processors and the mounts of the fan. --------------------------------- This part is important --------------------------------- 4- Look for the 2 black chips that are almost touching each processor above (or below depending on the direction the board is) and pay attention to their location to the chips for when the board is upside down.
5- Place your motherboard on a flat, heat resistant surface and set up to where nothing will touch it for 30 minutes.
6- Using the heat gun, heat the processors for 25 seconds a piece (less time the hotter the gun) using a circular pattern as not to have the heat focused in 1 spot. Then do the same for the 4 black chips.
7- Let the motherboard cool for 30 minutes. You will hear popping noises, this is the solder hardening back up after being set further in its socket. DO NOT TOUCH MOTHERBOARD. It is hot and any outside pressure or contact could snap it. Just let it sit there.
Whats happening is your are resetting any connection damage that might have occurred from the processors getting hot and not cooling properly. This also corrects any minor misalignment of the processor and its seat.
8- Flip the motherboard over and repeat steps 6 and 7.
9- Now apply a thin layer of the thermal paste on the back of each processor. Just enough so you that appears like you can see through it. Not literally but to the point that you think you can make out a letter on the processor.
10- Mount the fan back on carefully and clean up all excess thermal compound that may have been squeezed out the sides.
That should do it. Put the PS3 back together, leave the final screws unscrewed, hold your breath, pray to your deity and turn it on.
Like I said earlier, this happened to me I. I did this fix, failed because I didn't heat the processors long enough. Increased my heating time by 15 seconds each processor, and then my PS3 ran faster, smoother, and quiter for about 5 months before I had to do this fix again because my girlfriend doesn't like to turn my PS3 off (have to shorten auto shutoff to 1 hour now *sigh*). But fixed for a second time with same results.
Good luck gents. This solution does work, but you must also know that it may void the chance of Sony fixing this for you for 150. I paid $7 (US) for the thermal compound and $25 for the heat gun. And the PS3 are $300
Nov 30, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3  Black Console Logo
551 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
