Question about Epson LQ1170 Matrix Printer
In our Epson LQ 1150 printer the paper pulling tractor moves the reverse way when paper load button pressed.Please help.Paper does not come in the printer.
BU : **** PC : 7 LT POST BILL REGISTER FOR DEC-2011 COD: 31-DEC-11 BILL DT: 27-JAN-12 DUEDT:16-FEB-12 PAGE : 501
Consumer No Consumer Name DTC Code Pole No MR-Rute-Seq Supply Trf-Duty-JV PD/TD Sanc Conn Ind Dis
Date Date Load Load Code
Make-Mtr-No Dig M M Cur-Rdng Cur Prev-Rdng Prev Adj Consumption Avg Total Months
F S Date Reading Date Reading Units Consump
ASC
Fixed Charg EC Amount FCA TOSE ED Amount RLC RC Addl Charge PP Amount DR Adj Cur Int Cur Bill
LCR Units LCR EC LCR FCA LCR TOSE LCR ED LCR RLCLCRRC+AddC LCR Amt SD Held SD Inst SD Arrs SD Dmd
Op Arrears Op Int Prev Bill ***. DPC DPC Charged Last Rct D Payment CR Adj Cl Arrs Cl Int Net Bill ADJ Type
DDF TOTAL DDF INST DDF BAL RGPPL CHG CFL INST Ag Frz Arrs FOCA ADJ Ag Frz intGENCO Chrg.
VILLAGE : 33518 SHIRWAL
333330570588 SHRI SHRISHAIL MALKAPPA BIRAJDAR 9961007 17-1709-0001 19-OCT-10 80-49-05 5 5 A-00 LIVE
Meter 1: 50-00044633 5 1 0 31-DEC-11 8777 30-SEP-11 6827 0 1950 638 1950 3
Meter 2: 0.00
0.00 975.00 312.00 0.00 0.00 0.00 0.00 0.00 12.87 0.00 79.10 1287.00
0 0.00 0.00 0.00 0.00 0.00 0.00 0.00 3000.00 0.00 0.00 0.00
1777.80 40.73 1241.25 25.74 24.83 0.00 0.00 3043.88 40.73 4450.71
0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
333350587391 SHRI TAMBOLI KASIM BANDUBAI 9961006 17-1709-0001 04-JAN-10 80-49-05 5 5 A-00 LIVE
Meter 1: 53-08270080 5 1 0 31-DEC-11 8237 30-SEP-11 7067 0 1170 383 1170 3
Meter 2: 0.00
0.00 585.00 187.20 0.00 0.00 0.00 0.00 0.00 7.72 0.00 60.37 772.20
0 0.00 0.00 0.00 0.00 0.00 0.00 0.00 1800.00 0.00 0.00 0.00
1419.42 151.80 407.25 15.44 8.15 0.00 0.00 1834.82 151.80 2819.19
0.00 0.00 0.00 0.00 0.00 43.20 0.00 0.00 0.00
335480607406 SHRI MULLA ISMAIL GHUDU 9961006 17-1709-0001 10-JUL-09 80-49-05 5 5 A-00 LIVE
Meter 1: 65-06069283 5 1 0 31-DEC-11 17327 30-SEP-11 15377 0 1950 638 1950 3
Meter 2: 0.00
0.00 975.00 312.00 0.00 0.00 0.00 0.00 0.00 12.87 0.00 153.70 1287.00
3669.28 560.33 1241.25 25.74 24.83 29-DEC-11 3000.00 0.00 1935.36 560.33 3936.39
0.00 0.00 0.00 0.00 0.00 1440.00 0.00 0.00 0.00
7894550621646 BHIMASHA ADVAPPA BIRAJDAR 9961006 17-1709-0001 10-JAN-09 80-49-05 5 5 A-00 LIVE
Meter 1: 65-0 5 1 0 31-DEC-11 20927 30-SEP-11 18977 0 1950 638 1950 3
Meter 2: 0.00
0.00 975.00 312.00 0.00 0.00 0.00 0.00 0.00 12.87 0.00 302.60 1287.00
7228.86 1302.76 1241.25 25.74 24.83 30-MAR-10 0.00 0.00 8494.94 1302.76 11387.30
0.00 0.00 0.00 0.00 0.00 2611.08 0.00 0.00 0.00
HOW TO SORT THIS KIND OF NOTEPAD FILE USING CONDITIONAL STATEMENT
Posted on Mar 13, 2012
MJS_1
  • 150 Answers
SOURCE: Epson LQ-590 Matrix Printer Paper feed Problem
Assuming that you are feeding the paper into the correct end of the printer :), it seems that the printer is defective, but
First unplug the printer from the wall, wait a few minutes,
and see if it resets. If that does not work, read on.
  1. Printer rollers (and sometimes head movements as well)
    are controlled by "Stepping Motors"
    Unlike an ordinary DC motor with two wires, that spins
    clockwise or counter clockwise depending on the voltage
    polarity,
    a stepping motor contains several pairs of wires, that
    are pulsed in a controlled sequence, causing the motor
    to spin in precise angular steps. Depending on the
    number of wire pairs (poles) and internal gears, the
    stepping motor can have a resolution as course as
    90 degrees, and as fine as 0.05 degrees per step,
    depending on the cost and applications.
    Linear stepping motors can even move an object in
    a straight line.
    The benefit of these stepping motors is that, unlike a
    linear servo motor, they do not need complex positional
    feed-back for precise control, they simply step as many
    times as you tell them to. Four steps left, two steps back
    .... etc.
  2. These stepping motors are in turn driven by semiconductor switches (transistors) which are
    ultimately controlled by a central processor within the printer.
    Depending on the printer model, and how sophisticated
    the printer's internal processor is, the paper and head
    movements can be either automatically controlled by
    SOFTWARE (firmware) within the printer itself, or by the device drivers installed in Windows.
    The more self-sufficient the printer is, of course, the less
    hassle and CPU overhead on your PC.
  3. When any of the components within this chain of command fail, the stepping motor will move incorrectly:
    a) Skip steps
    b) Get stuck
    c) Oscillate back and forth
    d) Spin backwards.
  4. The causes could be:
    a) One bad wire in the ribbon connecting the motor
    to its controller board.
    b) Bad motor driver transistor: Open or shorted.
    c) Bad data line from the printer's internal control
    processor to the driver transistor array.
    d) Bad processor chip, memory or firmware within
    the printer, e.g. a burned out register or firmware
    memory location.
    e) Defective internal power supply, causing everything
    else to malfunction.
    f) Bad paper position sensor
    d) Crashed control program, which is probably the
    only thing that is fixable:
    i) unplug the printer from the wall socket, wait a
    few minutes, and see if it resets.
  5. It is also remotely (theoretically) possible, that
    the Window drivers are corrupt but this is very unlikely.
  6. If you are fairly brave and want to take the printer apart, and have some electronics knowledge and a few basic instruments, probe the roller drive motor wires, and see what gives. Is one wire stuck consistently low or high ?
    Is one of the motor windings open or shorted ?
    Is one of the driver transistors fried ?
    This very much depends on your level of skill, and the test equipment you have to work with. If you don't have a decent oscilloscope you will not get far. Without a digital multimeter you will not get anywhere at all.
Also do not forget that printers are dirt cheap, less than the ink when it runs out, so this may not be worth your time and effort.
Call the manufacturer, scream blue murder, accuse them of setting your house on fire and giving your dog diarrhea ....
and see if they will send you a freebee.
Hope this explains it.
Please rate my answers.
Martin
Posted on Jul 18, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
Stickx
  • 148 Answers
SOURCE: wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Posted on Jun 27, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
How to adjust the top margin for epson lq-2190
Turn on the printer.
Load paper
Press the pause button until the pause light is flashes.
Press LF/FF button to move up or LOAD/EJECT button to move down.
Press the pause button to save.
This save is permanent until you change later.
May 09, 2012 | Epson Office Equipment & Supplies
When paper loaded on tractor and press load paper at that time tractor rolls reverse why this happens?
I am sure your paper release lever is in single sheet position in which case the printer pulls back the continuous pater to allow you to add single sheets. Check and comment.
Aug 14, 2011 | Epson LX-300+ II Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
May 19, 2009 | Epson LQ-2090 Matrix Printer
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Wrong adjustment using epson LQ-2180
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Epson lq 2080 printer problem
These steps apply to a Windows system.
1. Click on "Start", "Settings", "Printers".
2. Right click on the icon for your printer and left click on "Properties".
3. Click on the "Paper" tab. Here you should see a "Paper Source" option.
4. Make sure that "Tractor" is selected and not "Manual" as the paper source.
5. Once this change has been made click on "Apply" to save the change.
6. Now try printing a document.
Apr 26, 2008 | Epson LQ 2080 Matrix Printer
632 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
