Question about Acclaim Constructor for Windows, DOS
I have Constructor (game of Acclaim) and I tried to play with dosbox but it doesn't work on fullscreen.
HOW TO INSTALL BORDERLANDS ADD ON GAME PACK ORIGINAL GAME CD
You need to get a copy of either DOSBox or VirtualBox to help you play older games on your newer system. You can download them and learn about them from the links below.
Dosbox:
http://www.dosbox.com/
VirtualBox:
https://www.virtualbox.org/
Aug 18, 2012 | 2K Games Borderlands patch
I have lighthouse/darkbeing 1996 and it will not install on my computer I have windows7 on mty laptop
This is an old program (DOS/Windows 3). It will not be compatible with a Windows 7 computer. (If you have the 64-bit version, you probably will have even more compatibility issues.)
Try using the program DOSbox, a DOS emulator: http://www.dosbox.com/download.php?main=1 . Download the Windows version (it will work under Win7 x64 and 32-bit). Install the program then see if you can install the game. If that doesn't work, you will need a program that can make a .iso (image) of the CD. A possible option is MagicISO Maker: http://www.magiciso.com/download.htm . Save the iso to your hard disc and then mount the image in DOSbox . This is a two-step process much like in UNIX. You will need to mount the hard drive and then mount the image. The commands would look like: mount c "c:\images"
imgmount d "C:\Lighthouse.iso" -t iso
Then go to the D drive and run the game as you did when you played on your previous computer.
I hope this helps.
Sep 14, 2011 | Computers & Internet
Constructor does not want to run on my windows 7
It's a very old piece of software. If you have windows 7 professional or ultimate you can install virtual XP which will allow you to install older DOS programs.
If you have an extra copy of Windows XP or lower you can install that next to your copy of Windows 7.
Alternatively you can install Oracle Virtual Machine that lets you run a virtual machine inside of yours which could be Windows 98 which would be much better suited for installing that.
Mar 01, 2011 | Acclaim Constructor for Windows, DOS
Hello there, My problem is with Worms: United and Reinforcements. I am trying to play on a Windows Vista (clearly well beyond the capabilities for playing such an old game) and the installer won't...
Hello Reagan,
In DOSbox you are able to map / mount a local drive from the gues DOSBox software to the windows host machine so that DOSbox can see it. I do this all the time - I have a drive on my windows machine C:\oldgames - and I issue the command
let me know
May 01, 2017 | The Adventure Company Video Game Consoles...
How do u find the ms dos drive
That's because ms dos isn't supported in windows xp
Check out this site for dosbox, a dos emulator
This program should allow you to run all your old dos games
even has support for windows Vista
Nov 02, 2009 | HP Compaq 6510b Notebook PC
Interactive Magic Apache Windows 95 program disk does not load into HP Pavilion - Light Strobe DVD/CD Burner. I have Windows Vista. Can it be done?
You must use Dosbox, get it at www.dosbox.com. Follow instructions and you will be able to play most old dos games. I started playing Apache 95, the game before the one you're trying to load and it plays just fine with graphics, etc... I love that game and when computer technology got better my old dos games fell by the wayside until I found dosbox.
Aug 31, 2009 | Interactive Magic Apache for Windows, Mac,...
Hp laptop,,vista os,,turboc not working in full screen
In order to get the full screen use the key combination of Alt and Enter
If you right click on program, in properties,you'll see an option called program compatibility. Make compatible with earlier versions
Jul 28, 2009 | HP Compaq 2510p Notebook PC
C++ doesnot get full screen on windows vista home premium c++ does not get full screen on vista business it gave a message ignore or close
Download DOSBox0.72-win32-installer.exe from dosbox.com and copy your C++ into that. Before copying follow the instructions.
This will give fullscreen support and can play all the dos games also.
Hope this will be helpfull
Thanks & Regards Nandu :)
Mar 03, 2009 | Microsoft Windows Vista Business Edition...
Acclaim Constructor for Windows, DOS Logo
118 people viewed this question
Top Acclaim Video Game Consoles & Games Experts
Tony
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an Acclaim Video Game Console and Game Expert? Answer questions, earn points and help others
