Question about Refrigerators
Hotpoint fridge FFM91 comes on and then cuts out. display shows temperature of fridge compartment
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: Inside Dsiplay Not Always on
Most likely it is the Main Control Board also called the Motherboard. It is located on the rear of the unit behind the smaller axcess panel. Becareful with the wiring if you attempt to change the board. There is a slight possibilty that it is the dispay board, but it is unlikely.
Posted on Nov 25, 2007
SOURCE: My Fridge is less than 2 yrs old. Yesterday I heard a clunking sound coming from the fridge
to clunk,
i have a GE model PDS22SFSALSS & it did the same thing...blinking LED & clicking, then LED went blank. i read that GE was having major problems w/ the mother board, (cost for part $ 153.75 & $79.95 for service call, they couldn't tell me the labor cost!! )on many models & were re-calling some. i called GE repair 4/8/08, got no help, then i called customer service & gave them my model & serial #. they said my box would be fixed (mutha bd swapped) for free. i bought it 10/05, they came the next day & installed new board free! start w/ GE 1-800-432-2737 .....good luck
denden8148@aol.com
Posted on Apr 10, 2008
woodchuck789
  • 4070 Answers
SOURCE: Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 08, 2009
woodchuck789
  • 4070 Answers
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Sep 04, 2016 | Refrigerators
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
Jan 11, 2009 | Hotpoint Refrigerators
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Aug 14, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
