Question about Toshiba Satellite P305D-S8828 Notebook PC
Mouse pad mouse sticky why???p - Toshiba Satellite P305D-S8828 Notebook PC
I have a Logitech LX-6 cordless optical mouse. Lately it's been double clicking when I press the left button - not always, but often enough that it's irritating. I'd like to take it apart and clean the...
Quite often there is a label on the bottom and this hides a screw which holds the mouse together. If there is a label on the bottom, try rubbing your finger over it to see if you can feel a hole underneath. Also on the bottom are plastic glide pads which help the mouse to move freely. If there is a large one towards the back then it may also hide a screw. Use a thin blade to lift off the glide pad and hopefully the sticky layer will remain sticky to make it easier to put back.
Feb 25, 2011 | Logitech Cordless Mouse
The base has lost its stickiness and no longer holds the velcro pad that you attach the sandpaper to.
I had same problem. Go to the hardware store and buy some Velcro strips. One side has adhesive, just put that side on the mouse. I had to put several strips on then cut around the shape of the mouse. Sandpaper for the mouse sticks to it great. Just be careful when pulling the used sandpaper back off that you don't tear off the Velcro. I threw that little pad away that was originally on the mouse.
Dec 09, 2010 | Black & Decker Mouse Sander/Polisher
My notebooks mouse pad is very sticky
this touchpad must be 100% dry and your fingers also
Oct 02, 2010 | Compaq Computers & Internet
How to turn on the mouse pad it doesnt seem to be working??
press the fn key and the f key ( ie f1 f2 f3 ect ) together, cant remember which f key it is and one of them will work, they are called sticky keys.
hope this helps.
Aug 15, 2010 | Computers & Internet
Will rubbing alcohol on bottom of mouse or computer mouse pad resolve a sticky mouse from sliding
it will work on the mouse its self, for the mouse pad throw it in the dish washer on the top rack then let it air dry.
Mar 24, 2010 | Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD...
PC.mouse goes sticky very often.Normal mouse with
Sticky you say? try cleaning the optical lens (the red light under the mouse) also try a different mouse mat.
Regards.
Jul 14, 2009 | Logitech 9311570403 Mouse
Sticky mouse
Search for out other postings here at FixYa. The sticky situation is one I had, but it was the actual wear inside the mouse buttons to microswitch contacts. I would have to click numerous times to get my mouse to function. The plastic pads get worn after some intense use. Check for our solutions here in other postings.
Jul 13, 2008 | Logitech LX7 Cordless Optical Mouse
Toshiba Satellite P305D-S8828 Notebook PC Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
