Question about Medium Tsunami Saltwater Fishing Rod Conventional 6'6"
My Tsunami surf rod broke today while pulling in bluefish. How can I get this covered by warranty?
My fuses and housing look like water damage got me. Warped, bluefish white all over
pull out all the fuses and spray clean with wire spray.clean or change all fuses.put some white grease onto the fuseholder and put back all your fuses
Jan 18, 2015 | Motorcycles
Why was I told the aluminum anode would not work in my Whirlpool WH? Had it removed today after three weeks and it was covered with matter. Now have $60 Whirlpool rod installed on my lifetime warranty...
1) Ask question on pro water heater site run by foremost anode expert, and also ask about the power anode rod that works electrically instead of chemically and will not have repeated problem you describe:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) More info about anodes:
http://waterheatertimer.org/Replace-anode-rod.html#power
Mar 21, 2013 | Whirlpool Water Heaters
Jack on my monster beats broke what do I do?
The warranty will not cover it, it will be called abuse.
Go to your local electronics store(radio shack) and buy a plug you can rewire with.
Feb 17, 2012 | Monster Cable Products MH BEATS IE...
Hi,I have a 2003 deuce done 11000 mls, rode it today felt asthough the clutch cable broke (no clutch) ,after further inspection clutch cable seams to be alright connected both ends,haven't pulled side...
Well, you only need the clutch to release, and that cannot be major. Inspect the cable completely, does it move at the trans end when you pulll it. What is inside is essentially a fork on a release bearing, a rod, and the clutch spring plate.
Oct 10, 2010 | 2003 Harley Davidson FXSTDI Softail Deuce
I have a 1980 Suzuki GS450L that broke a chain today while my son was riding it. The chain wrapped the drive sprocket and bent the clutch push rod. It appears mine doesn't have the seal mounted on the...
clutch pushrod should just pull out as it should be a 2 piece clutch pushrod model, earlier models were 1 piece and you had to remove clutch cover and pressure plate to remove. hopefully the seal is ok.
Sep 02, 2010 | Suzuki Gs 550 L Motorcycles
Driver side door wont open.solution on opening the door
This is usually caused by a broke plastic retaining clip.the inside handel should have a insert covering a screw pop out the insert and remove the screw. If there is no rod atached to the handel (broke clip) locate the rod in the door (a metal coat hanger works good) pull on the rod towards the front of the door and it should open.Replace the clip or sometimes the handel itself breaks needing replaced.
Hope you get a handel on it!!
Oct 23, 2009 | 1993 Honda Accord
Clutch push rod broke !!!
Chances are the prior owner installed some aftermarket springs that are too strong. This puts extra pressure on the push rod. Just pull the left and right cover of then remove the clutch assembly. put the new rod in from the left side then re-mount the left cover. Put the clutch back on then the right cover. The parts book shows a two piece push rod assembly. I wonder if a hardware store rod was installed because the factory rods are near impossible to find. The substitute rod probably couldn't handle the pressure and heat.
If not found elsewhere, google motorcycle salvage suzuki and see if you can find a used rod set.
Sep 22, 2009 | 1985 Suzuki GSX-R 750 F
Sounds like something broke in motor 1988 corsica 4 cylinder
If the sound is coming from the block, than it probably is. the rod broke from piston pin. Don't run motor if it is like this or the rod WILL go through the block.
If it is from the head, it may be a push rod.
Jun 02, 2009 | 1988 Chevrolet Corsica
Medium Tsunami Saltwater Fishing Rod  Conventional 6'6" Logo
53 people viewed this question
Top Medium Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Medium Fishing Expert? Answer questions, earn points and help others
