Question about Haier hwr10xc6 Air Conditioner
Haier air conditioner blowing water
Water coming out of air vents and the unit is making a squeeking noise
SOURCE: 9000btu Haier portable air conditioner
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Posted on Jul 18, 2008
koolbreezes
  • 540 Answers
SOURCE: window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Posted on Sep 02, 2008
  • 10865 Answers
SOURCE: New Air Conditioner is rattles extremely loud
If your air conditioner is new, it is under warrantyl you must contact the store as you dont want to void your warranty.
Posted on Jun 29, 2009
  • 10865 Answers
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
What causes awindow air conditioner to blow water out
It could just be condensation depending on the level of humidity in the air.
Jul 26, 2012 | Haier Heating & Cooling
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
There is red light that is blinking on the power button. None of the controls work, and there is no air blowing.
IF YOUR UNIT IS STILL UNDER WARRANTY CONTACT HAIER AT 877 3373639 FOR AN AUTHORIZE SERVICE CENTER NEAR YOU.
IF YOU ARE NO LONGER COVER UNDER WARRANTY YOU COULD TRY THIS THERE IS A DRAIN PORT LOCATED AT THE BOTTOM OF THE UNIT. OPEN IT AND SEE IF ANY WATER COMES OUT. THE WATER COLLECTION TANK COULD BE FULL CAUSING THE UNIT TO SHUT OFF. raypena_8.jpg
Jun 01, 2011 | Haier HPRD12XC5 Air Conditioner
The air coming out of my Haier CPRB09XC7 Portable Air Conditioner has gotten warmer and dryer. I'm sure that i need to add water but i do not know how as the manual was lost a while ago. Do I just need to...
Actually, sportsfan, you don't need to add any water. In fact, there is no way to do it. Your unit works much the same way a dehumidifier does with auto evaporation function. In other words, it collects the humidity out of the room air a evaporates it, so there is no water removal on your part involved. While this water is being evaporated, it's also being cooled, so that cools your room. The hot air of the unit running is exhausted out through the window vent kit.
To replace your Owners Manual call Haier Customer Support 877-337-3639
Hope this helped answer your question. Please let me know. Thanks.
May 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Blowing water
Window Air conditioners need to tip back just a bit in the window...if they are flat or tipped front you will have the water problem...
Here also is a tip that will help you to keep you Air Conditioner running well...
Window Air Conditioners - Clean them every year
heatman101
May 07, 2010 | Haier hwr10xc6 Air Conditioner
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
My haier a/c window unit is spitting water through the vent
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Haier AC HWR10xc6
Haier Air Conditioners do not have a drain hole or hose like most A/Cs. This problem can easily be solved by carefully drililng about an 1/8 or 1/4 inch hole in the bottom outside edge directly on the metal frame, around the cooling fins.... This will elt the water drain out...if you when outside and looked in while it was spitting you would see the water pooling up in there. Haier expects us to mount these units at an ungodly angle to drain the water, but drilling a small hole will help (really anywhere in that bottom plate would work since the whole bottom is a "drain pan"
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
369 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
