Question about Xerox 8830 Copier
Xerox xc830 there are three indicator lights on the front of the machine...toner...not lit...paper jam...not lit...and something that I would describe as a mushroom, that usually glows solid red, but is currently flashing...does anyone know what it is trying to tell me? The reference on the side of the copier shows the same picture to correct as replacing the toner cartridge...please help, machine will not copy...was working fine just prior to light starting to flash.
  • Anonymous Feb 07, 2009
    Yep...I have same problem. Bought a new toner cartridge (8300 series) couldnt find a specific one...and this did not cure the problem. Suspect this cartridge may not be making contact in all the right places. At a loss for anything else. Wish the previous post had gotten an answer.
  • Anonymous Apr 14, 2009
    What should I use to clean the drum, I get streaking on copies and toner collects on drum
    President:
  • 2,072 Answers
It does sound like the toner cartridge is empty or bad.
Posted on Apr 22, 2008
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
When the "add toner" and "toner disposal" lindicators lit, I continued copying, until the indicator "memory overflow/data error indicator" lit - and no more copying was possible. Then I replaced the toner...
you have to reset the tonner counter and the drum ..and after that try again ...you will also have to empty the memory so to be able to take jobs ..Im not sure about the reseting procedure..but try to shut it down ..than unplug ...plug it back and press the power button and keep it pressed until it beeps ..will be about 15 seconds or so ..If this will not work ..take a look in the manual and see if they explain the exact procedure..
For other similar models you have to open the front door to get it into service mode..than from the service mode with the arrow select reset ..than one by one reset all ...toner counter ..drum ..and waste tank ..after that will do ..
Aug 20, 2010 | Panasonic Workio DP-4530 Copier
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
449 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
