Question about Car Audio & Video
Re Coding my Siemens CDR 500
I have my code number but i can't enter the code because i can`t go through the entire process because when i sing off the cd player and beguin the process always i only see the sefe message with the number of imputs i have until the CDR 500 bloking down. PLease someone can tell how can i resolve this problem to ente the code ?
  • george_louca Aug 16, 2008
    i dont have code number i have tell me your number
Hi, Try this:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Hope it helps.
AlterEgo
Posted on Jun 30, 2008
    New Friend:
I had a problem whereby, for no known reason, I started my car one morning, the radio came on for a split second and displayed PANEL and was from thereon silenced. Although I could get as far as 10SAFE by following the instructions in the manual, I could not get any further.
This worked for me...
You will need a 2mm allan key and a set of keys/prongs to remove the cdr 500 unit.
1. Switch off the cdr 500
2. Switch off the inginition
3. Remove the 4 grubs screws in the unit facia
4. Insert the removal keys/prongs and extract the unit from the console/dash
5. While you have it out check the fuse and the connectors at the rear of the unit
6. Re-insert the radio ensuring it locks in position
7.Turn on the iginition
8. While holding down the [AS] key turn the cdr 500 on
9. Keep holding the [AS] button until you hear a beep
10. CODE ____ is now displayed
11. Enter the security code
11. Confirm the security code
All working again.
Posted on Feb 01, 2014
  • lizzy more
    lizzy more Dec 03, 2014
    Had exactly the same issue...lots of leaving ignition on for hours to no avail...then I found your post & it worked!! Thanks for putting this up.
OH oh oh .
You do this way.
1) TO TURN ON THE ENGINE
2) I normally tries to insert the code
3)The number of the remeined attempt and the word SAFE it appears
4)You leaves always the motor turned for 25 minuts
5)The available number of the attempt and the four lines it will appears for putting he code
6) To insert the code
Ciao. Mauro
Posted on Jul 22, 2008
Have no code for siemens radio
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Aug 24, 2012 | Car Audio & Video
Need code VDO 330886636 No.24469302
I NEED RADIO CODE FOR SIEMENS VDO 330886636
n? 24469302
type CDR 500(E)
2F4
Feb 07, 2012 | Car Audio & Video
How do you enter the radio code, for a siemens vdo cdr 500. please can you advise
Vauxhall Delco CDR 500 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Sep 01, 2010 | Car Audio & Video
Need code for siemens vdo 330886636 no 24 469 302 type cdr 500(e)
I NEED RADIO CODE FOR SIEMENS VDO 330886636. No.13 138 246. GM020521690276.PLEASE HELP ME.THANKS!
Aug 19, 2010 | Car Audio & Video
I need a code for my siemens vdo stereo type cdr 500 serial no; gm050032037535
Unfortunately SIEMENS/VDO codes for the CDR500 are only available from your Main Vauxhall Dealer or a Radio Decoding Service
Apr 10, 2010 | Car Audio & Video
My siemens VDO, cdr 500 car stereo has been locked due to my car battery going do you now the code
These CDR500 codes are only available from the Main Dealer or Radio Decoding Service
Not available for free from anywhere on the Internet
Sorry
Feb 07, 2010 | Car Audio & Video
Opel factory fitted radio codes i have a siemens cdr 2005 the serial number on the side is GM020543462810 i need the safe code but it is stuck saying 7 safe and wont let me enter another code
Unfortunately the majority of SIEMENS/VDO codes (including your CDR 2005 )  will  NOT  be available for free (or cheap)  from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
To reset from 7SAFE  then LEAVE SWITCHED ON ....UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two)
Dec 07, 2009 | Car Audio & Video
I require a radio code for a stereo CDR500 (Vauxhall) number GM0500W9357274
The CDR 500 is made by Siemens VDO (DELCO) and unfortunately the code is not available for free from anywhere on the Internet.
Available from your Main Dealer .....or a Decoding Service who will plug in a laptop to read/recode the memory chip (EEPROM)
Sep 07, 2009 | Car Audio & Video
Car Audio & Video Logo
2,117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
