Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Won't print over network
I currently have a Bizhub c450 however it has been taken to the shop for repair due to a power surge.
They gave us a loaner (Bizhub c250)
Here is the problem.
When we first set it up on the network every computer (4 in total) could print to the bizhub and scan from the machine.
However yesterday after about 3 hours it disappeared of the network. You could see the name of the machine. But when you try to connect it would say not found on the network.
I closed shop and shut down everything as usual.
This morning I turned everything back on and to my amazement everything was working.
Now about three hours later it has done it again. Vanished off the network.
I decided to power it down. I waited about 3 minutes then powered it back up.
Guess what it came back on the network.
Is this a normal problem for this machine, because the same thing happened to the C450
I am just curious if anybody has any ideas
    Champion:
  • 214 Answers
If same thing happened with c450, then i guess, that the problem is in the network. does the printer answere a ping, also you can ping from printer to network. maybe youll find something. but last option is that you have to upgrade firmware or change network board, also check network settings from printer.
Posted on May 11, 2008
3 Suggested Answers
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
How i can rest error code c-d231 on bizhub c450
CD231 in Bizhub C450 come due to missing of DIMM memory board in Fax board.
in service mode(Utility-counter-Stop-00-Stop-01) -system2-option board-unset the Fax1 and fax2 and re-start machine .
Jul 03, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Minolta c450 Network Print- Data comes at the machine end but no print
does this happen with word , pdf, web pages, email? what other indication display on screen
Jan 02, 2014 | Konica Minolta bizhub C450P Laser Printer
Bizhub c450
On your printer settings on your computer when you select to print there should be a box that says only use black ink. Try that first and if it still prints in green you may have them in the wrong ports.
Aug 18, 2013 | Office Equipment & Supplies
Log in error with bizhub c450
We have been having this problem and I am trying to find an easy way to push the fix out to all users automatically. What I have found is that the driver automatically inserts the Windows network login name as the user name under "Authentication/Account Track" insteead of the "Public" user. Even though I have it set to Public User in the driver on the print server (and defaulted to Grayscale), It has to be manually set for each user on their PC's driver. More often than not, it also has to be set in the Printing Preferences in the application the user is trying to print from (Ex. MS Word, Acobat Reader, etc.).
Mar 05, 2012 | Konica Minolta bizhub C450P Laser Printer
Hi nwillett,
Regards
Taminol
Mar 11, 2009 | Konica Minolta bizhub C450P Laser Printer
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
633 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
