Question about Kenwood Sirius KDC-MP825 CD Player
I turn the key on and the face will flip out but with out any thing on the screen
  • Kenwood Master
  • 17,130 Answers
There could be a possible failure of the link membrane connection that goes from the head unit to the panel. You will need to open the head unti and look at the hinges from where the flexible cord move along.Look carefully for a sharp cut that will be visible only at the bendings. If you ahve detected this remove from the panel and replace with the similar one. However if this seems alright then you will have to check the power to the screen from the main PCB. Use a voltage check onthe main power , the sub power and trace it slowly to the display section. If the Cd palys but except for display everything seems alright, then you will also have to open up the display drives for a voltage/frequency check . Look for any failure of the protector zener mounted alongside the drive. I hope you could get some idea . Good Day
Posted on Jul 08, 2010
How do I set screen rotation
Simply hold down Control + Alt and then select the arrow key for which way you want your laptop or PC screen to face. Your monitor will then go briefly go blank and will return in a few seconds facing a different orientation. To restore this back to the traditional settings, press Control + Alt + the up arrow.11 Nov 2014
How to rotate a laptop or PC screen ' Alphr
www.alphr.com/features/.../how-to-rotate-a-laptop-or-pc-screen-flip-your-display-sidew... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+set+screen+rotation+pc+laptop
Nov 29, 2016 | Computers & Internet
My screen has turned 180 degrees how do I revert back please
try to find out, who did install this flip the screen thing on your computer. Or where it is on the computer and remove it.
Jan 18, 2015 | Asus Notebooks ASUS R704VD-RB51 17.3"...
Front facing camera not working
Could be a bad front facing camera some times HTC phones will do a flipped shot of the rear camera when the front facing one is bad. Had a couple EVO 4Gs that did this same thing replaced the front camera and worked perfectly. The replacement front camera is relatively cheap and installation is half way easy if you have some electronics experiance.
Mar 17, 2014 | HTC EVO 4G Smartphone
Is there a special cord to charge a flip video or do you just plug into computer withjack atttached to camera
hey guys! flip not turning on after charging? well, i have gotten a solution for you. before doing any of this, please read all directions. first, look at bottom and slide to unlocked key. then, gently slide off front of flip, with thumbs pressing down, to where batteries are stored. after taking out batteries, up top you will see a small and flat gray box with a mini black thing sticking out of it. take something sharp, like a pencil or pen, and press down to the back, closer to lens, that black thing for sixty seconds exactly. one minute to be exact. next, slowly put the batteries back in correctly, and put on the cover of your flip. at the bottom, slide to locked lock. wait three minutes or so. then try turning it on. after you see it works, plug it in to the computer as quickly as you can. the way you do that is by sliding metal piece down on side until a plug shoots out. you plug that in to the correct sized jack on your computer. let it charge as long as half as a day. before unplugging, eject the flip in the right hand corner on the computer screen. CONTINUE READING!! if still when you plug it into the computer after the metal box process and nothing does anything on your computer that is no good. if no boxes that say download pix or anything don't pop up that is the same. look in the bottom right corner of computer screen and maybe something is there. if not any of those thing, repeat the whole process of this paragraph over again. after doing this process a few times your flip and still not working might be trash. after doing metal box thing a few times and it does not turn on it might be trash. by the way, i am a ten year old girl in fourth grade who likes cheese, has a flip, and lives in NJ. thanks guys! i am always willing to help out others.
emma
Oct 07, 2011 | Flip Video Flip UltraHD 8GB High...
My son's dell Inspiron mini is having problems after sign on. The Desktop and windows that appear after that are reading upside-down and we cannot figure out why it happened. Any advise to get it...
I think that Ctrl+(Alt and/or Shift)+(Up or Down) should fix it. There are a couple of key combos to check, but I'm sure that one of the above will fix it for you.
If the key replys dont work you can go into the advanced settings of your video card and set it there. On my x1400 I can do the same thing in the ATI Catalyst Control Center. Once your in there you can turn the Hot Keys off that will flip your screen like that and you can also flip your screen the right way round.
Steps to get there if you have an ATI video card and ATI Catalyst Control Center installed.
1 - Right click on your desktop.
2 - Select "properties".
3 - Select "settings".
4 - Select "advanced".
5 - Select "ATI Catalyst Control Center".
6 - Select "Displays Manager"
7 - Once the "Displays Manager" tab opens you should see at the bottom tab you should see a box marked "rotation". Set your rotation to 0 degrees landscape.
While you are also in the ATI Catalyst Control Center you can also click on the "Hot Keys" tab and turn the ATI hot keys off that flipped your screen in the first place. John
Feb 08, 2011 | Dell Inspiron Mini 10 Notebook
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
My LG Shine Flip phone turns on but all it shows is the LG symbol on the main screen, and it says Downloading... on the outside screen. Every once in awhile it turns on fully and the 2580 keys do not work,...
most of the filp models face this prob,, answering and function keys are 1 strip,display 2nd strip, # * 1234567890 3rd strip, so change the number strip for 2580 prob,,,, for downloading prob reset the phone with the default code1234 or 0000
Mar 26, 2010 | LG KE770 Shine Cellular Phone
Need to change the hand-set remote battery
To replace the battery:
1. Press the button to flip out the key.
2. Turn the key fob so the metal key stick out to the right and the channel that the key fits into is facing you. (The VW logo on the fob will be facing up)
3. Look closely inside the channel. It is split vertically. On the left hand side of the vertical split, it is also split horizontally.
4. Insert a flat blade screwdriver into the horizontal split and twist. They key fob will come apart, revealing the battery.
5. The replacement battery is a 3 volt CR2032 'button cell' and is commonly available.
6. Replace the battery with the + side facing down.
Oct 26, 2009 | 2000 Volkswagen Beetle
Camera Turns off when Display is rotated then closed
ur strip line is broken dont use ur screen with more rotation
Jun 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Kenwood Sirius KDC-MP825 CD Player Logo
63 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
