Question about Samsung HLR5067WX 50" Rear Projection HDTV
Replace bulb turned on tv. had picture. heard a pop. no picture. then snapping sounds. I guess the bulb popped. But I don't even know how to change it. Nor do I know how much the bulbs run these days. I know they were super expensive when they first came out.
  • Samsung Master
  • 8,617 Answers
There is a small access door on the rear panel of the set. Open that door and you will see the lamp cage it pulls straight out.
Posted on Jul 08, 2010
Toshiba 37" LCD flat screen. I heard a small
Get a quote from a TV repairer then you can decide if it us worth repairing.
Mar 30, 2013 | Televison & Video
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a mitsubishi wide screen television. I heard a loud pop noise, and now I have no picture. what is the problem?
If you have a projection TV, you have likely lost a bulb. Don't worry, it happens from time to time and it's really easy to fix. Just Google the model number of your TV and projection bulb. Sometimes they come as just the bulb or the entire assembly. Purchase the whole assembly if you don't feel comfortable taking things apart. In the back of the TV there is likely a small door that opens (Possibly with a screwdriver), the old assembly will slide out and you just have to replace it with a new one. A bulb can run anywhere from $50 to $120 but it's inevitable that they will burn out like any other bulb. At least they are easy to replace.
It's also possible that the sound was a capacitor blowing. This happens more frequently in the summer because there are electrical power fluctuations due to Air Conditioning. You can search Youtube for "Capacitor Explosion" or "Blown Capacitor" to compare the sound. If that's the case it will need a repair.
If you know someone who can operate a soldering iron it should be an easy fix. There will be a very obvious blown capacitor on the main board of the TV and it will just need to be swapped with another one. If you're not paying for labor this is going to cost you less than $5 in parts. Google "Badcaps" for instructions on replacement.
Jul 24, 2012 | Televison & Video
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Samsung HLR5067WX 50" Rear Projection HDTV Logo
125 people viewed this question
Henry  Thomas
Henry Thomas
