Question about Craftsman Garden
I HAVE A CRAFTSMAN KOHLER THAT WILL RUN WHEN
I HAVE A CRAFTSMAN KOHLER THAT WILL RUN WHEN UNDER LOAD BUT REVS UP AND DOWN WHEN STILL.i CLEANED THE CARB IN AN ACID BATH 3 TIMES AND STILL NO LUCK.IF I HOLD THE CHOKE 1/2 ON IT RUNS STEADY.IS THERE ANYTHING ELSE I MIGHT BE MISSING?
Sounds like a governor adjustment. there is a spring from the throttle actuator arm which slots to the governor actuator arm. Try different positions.
Posted on Feb 23, 2012
  • 448 Answers
The foat could be plugged or not alowing enough fuel to get into carb.
Posted on Jul 08, 2010
Why is there gas under the air filter on a Craftsman Mower Kohler KT735 or is this normal?
needle and seat not closing of properly and allowing fuel to leak out
check for excessive sump oil level
Jul 01, 2017 | Craftsman Garden
Kohler engine troubleshooting
Short in the magnito
Jun 16, 2013 | Garden
Idle rolling
are you talkin aboutit surgin up and downat high idel thats normal when you engage the blades it levels out under load
Oct 26, 2012 | Craftsman Garden
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Aug 25, 2009 | Craftsman Garden
RPM fluxuates/pulsates
It sounds like a piece of dirt is in carburetor.You could try the quick clean first,remove the flywheel screen and the plastic engine shroud.The top of the carburetor will be exposed now.Remove the 3 small screws from the plat on top of the carb.Use air or carburetor cleaned and blow out these passages. Be sure to cover with a rag when doing this to shield your face from spray back.Test run and see if that helps,if not you will have to remove the carburetor and disassemble it to clean it.
Jul 30, 2009 | Briggs & Stratton Garden
Garden Logo
367 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
