I have a WD 1600 B 015 i'm trying to find out what the bottons on the front do i know one turns drive on and off what are the other two for
    Problem Solver:
  • 10 Answers
I have looked over that hard drive and the two button underneath the Power Button are actually backup buttons. One is for manual backup and the second is for automatic backup.
This will clarify that: http://www.wdc.com/en/library/dual-option/2779-001014.pdf?wdc_lang=en
The above link requires Adobe Reader but will explain this to you on page 13/30.
Posted on Jul 08, 2010
How can you tell when your transfer case goes out in your vehicle I push the button that goes into four wheel drive and it blinks and it won't go or go into gear
Its kind of a tough question .
If your asking how would know for sure after pushing the magic botton if the vehicle is actualy in 4WD.
Its hard to tell what I would do is get all 4 wheels the ground .
Put it jack stands this it tricky and if you don't the equipitment or don't feel comfortable doing this then don't do it
In the old days you had to get out of the vehicle and lock the hubs and you know for sure it was locked .
Remember this never drive it 4 wd on dry pavement the wheels need to slip a little snow or dirt
Its not really 4 wheel drive its a limited slip system so olny 1 front wheel and 1 back wheel are grabbing at any one time so if a wheel slip's on the front on one side the other one will grab the same with the rear to give the best traction.
.These systems that are vaccun opperated or electroicly opperated don't replace locking the hubs .
A bad connection electricaly or the paper clip they tend to use to hold the cable on at the shift point are problmatic at best.
Mar 13, 2015 | Cars & Trucks
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
"CL" appearing on my LG
CL is for control lock /look at panal closly should be botton or bottons you press and hold to release the control panal...Good luck
Feb 01, 2011 | Washing Machines
When I'm in 4 wd the front wheels feel like the brakes are being applied when I make a sharp turn. No problems when driving straight or in 2 wd.
It sounds like you are driving in 4wd drive on dry pavement. The front drive axles do not work like the rear differential. When you turn, the outside front wheel must travel farther than the inside wheel, therefore they are traveling through the turn at different speeds. If you are on dry pavement, this causes the gears to bind. You don't notice this on slick surfaces because the outside wheel will slip instead of bind up the gears. You should not use 4wd on dry pavement. That's the advantage of push button, or shift on the fly, 4wd. You can shift back to 2wd when you encounter dry pavement. All wheel drive vehicles don't have this problem because they have a limited slip front differential as opposed to a locking differential on 4wd. Hope I didn;t confuse you too much.
Dec 21, 2010 | 2004 Ford Ranger
Can't turn on book. I have plugged it into wall. I pressed the round button on the front, was that a mistake? Wont' turn blue and power on. I have tried it in a plug I know works.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Western Digital My Book Essential Edition...
I own a Memorex DVD player, model MVD2030 which hasn't been used for 6 years (when I moved). Tried to set it up today and find the "open/close" button does not function. Any ideas on how to resolve this...
its not problem at all.
if you have an old stereo or tv set you can use one of the small push botton to replace it.
you will need screw drivers, solder, suction and some patience to do the job. that is if the botton is making bad contact.
the problem can be a bad driving IC.
try to open the casing, locate the open/close motor, turn it manually to fully open tray. plug the set into power and try to close the tray. does this happen and still the tray wont open with the botton, then your driving IC is bad. i dont know if you can change the IC, its small and maybe and SMD.
Aug 26, 2010 | Televison & Video
Exhaust front pipe nuts rusted on
Try using a size 10 metric thin walled socket drive to fit nut with a little force. Use plenty of WD-40, soak the nut and stud. Try to turn nut for 1/8 turn forward, spray WD-40 then turn bolt back until it feels that it is stuck, turn nut 1/2 turn forward, spray WD-40 and try again to unbolt, everytime it feels it is stuck move nut forward, spray WD-40 then try again to unbolt. It is a slow process as it to prevent stripping the rusted nut and stud. Have fun.
Apr 15, 2010 | 2005 Gilera Runner VX 125
WD My Passport 160 GB Hard Drive
It sounds like you need to update the driver s for your your devices,
Did you format the drive/s before loading info on to the drive???me,
XP works well and Vista should tooo.....so I beleive your devices may need updating thanks
Let me know how it goes that before you rate Me thanks
I have just finished installing a WD250GB
Cheers Misterdj
Nov 04, 2008 | Western Digital Passport WDXML800UE...
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
