Question about Vacuums
I have a hoover windtunnel bagless vac that is several years old. the floor vacuum part still works fine, but the handtool attachment has no suction and is useless all of a sudden.
    President:
  • 1,673 Answers
Don't have your model number, but some have a valve down on the noozle part that may be broke. When it is its upright position, the valve won't change over to the hose only position. You would have to remove the top cover to see this.
Posted on Apr 20, 2008
How do i remove the rewinder on a Hoover UH70120
Since you felt the need to ask this question, you are obviously not qualified for this level of repair. Take it to your local vac repair shop. If you have had your machine for less than 1 year it is still under warranty. If it is over 1 year old it is probably not worth fixing. New Hoovers are designed to last only one year and toss them ( as are most all bagless vacs for that matter ).
Jun 25, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel UH70212. Just a few months old. I used the attachments a while back and now there is very little suction. The power brush attachment doesn't work at all. Any suggestions?
If there is no suction, there has to be a blockage somewhere in the dirt path. You should hear the motor working a little harder in this condition. Please check the entire dirt path from floor to exhaust (clean all filters too) to find the obstruction.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Hoover U8341-900 WindTunnel 2 Bagless...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Left side of Hoover Windtunnel won't pick up dirt and hair
Take it to your local vac shop for repair. They can help you. It needs to be serviced annually anyway to perform properly.
Aug 07, 2017 | Hoover U5753-900 WindTunnel Bagless...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
Sep 13, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
