Question about Tunturi Exercise & Fitness
My J620 Tunturi treadmill is speeding-up out of control when I start it. In the past I have used the reset button or re-started. Neither works any longer. Can this be fixed?
  • 3,230 Answers
Well you can please follow the below steps -
1. You may have a belt and deck problem.
a) without the power on stand on the walking belt
b) push the belt in the direction it normally turns
2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try following -
a) Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
b) If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor.
Please post comments for further help or information.....
Good Luck!!
Thanks
Posted on Jul 08, 2010
  • mstarman Jul 12, 2010
    The solution submitted to me did not work. Any further sugggestions?
    Nickname: mstarman
    Password: 16e01
    mstarman
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
Feb 23, 2016 | Tunturi Exercise & Fitness
System check failure
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
Mar 30, 2014 | Tunturi T60 Folding Treadmill
Tunturi t7 showing error 20 !
this means the treadmills power reading when the treadmill was operating at speeds of 1 miles per hour or less . Excessive amount of power is being demanded from the motor controller for an excessive period of time
Causes:treadmill user (especially a heavier user) is standing on the drive belt.
the drive belt too is badly worn.
brush motor faulty
SCR motor cotroller lekay or shorted drive motor or capacitor
IN short RUN the sotware calibration for diagnostic.
Remedies:Lube the deck belt, determine using AC ammeter for the amount of use the current being drawn by the readmill.Replace the drive motor brushes.or replce the motor controller board. see the block diagram
God bless you
Oct 11, 2012 | Tunturi T70 Treadmill
Can not locate speed sensor in tunturi j620p treadmill
I also have a speed problem with my Tunruri J620. In the last week the speed gets erratic over 4.0 mph. speed sensor is not labeled on any diagrams in manual. I took off the cover and the only piece that seems possible is a black piece about 1 " square that sits on the edge of the control board where the board is notched for the motor flywheel. the flywheel has alternating reflective and black coating on the side facing this piece. I believe this must be the speed sensor and that it is an optical or maybe magnetic sensor that measures the time between the pass of each reflective mark on the flywheel. The black piece has a phillips screw that looks like an adjustment screw in the center. It is flush with the end of the control board which is about 0.6 cm from the face of the flywheel.
Sep 23, 2012 | Tunturi Exercise & Fitness
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
I am in need of a manual for a J620 treadmill. Is
I have the manual and am willing to scan for you. notlob101@aol.com
Oct 14, 2009 | Tunturi Exercise & Fitness
Exercise & Fitness Logo
57 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
