Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
I have a yard man 13AH762F752 How do I know what size my deck is I thought it was a 38" and bought v-type belt and it is to shore so how do I find out my deck size?
  • 760 Answers
If you have a single idler pulley you should have a 38" deck. If the deck has two idlers, then you must have a 42"deck. You should be able to approximate by measuring. This is the "cutting" width, not overall width. Two things might have happened. You didn't get the right belt, or you haven't routed it properly. Here is a link to the Yardman web site to download your manual if you don't have it. It appears that the 38" deck requires a longer belt than the 42" deck. http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10201
Posted on Jul 08, 2010
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
I bought a new deck belt # 954-04062 and its too long. i dont have the old belt. why doesnt it fit? this is what it calls for on the yard machine 38 inch deck
Do you have a large and very tight spring at the back of the mower body?? This needs to be pulled back to the triangle metal piece usually welded to the rear end axle. The spring pulls the entire mower housing back toward the rearend and tightens your new belt. John
Sep 12, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
What size & length belt do I need for my yard machine? It is 12.5HP, 38" cut. I don't have any other info with me. Tks
The best thing you can do is get the model # (probably under the seat of the machine) and go online to www.m-and-d.com and type in the model # and they'll give you the correct belt for your machine (from there you can probably buy locally).
Jul 06, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
What size drive belt does a 38in deck require? just bought a mower with no belt? Thanks
it depends what kind of mower you have, i have a 38'' mower that uses a 14'' belt.
Jun 12, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine Pulley 660 MTD Yard Machines
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
Jun 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Man 42'' Drive Belt Install
it is a mtd mower ,however you should be able to go to a tractor supply store with the decksize and the engine size and get the proper belt.AGAIN(TSC) store,OR TSC.COM HOPE THIS HELPS
Jun 08, 2009 | Mtd Garden
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
638 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
