Question about Microsoft Windows XP Media Center Edition 2005 for PC
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even tried running the computer in safe mode and it wouldn't let me do that. The Technical Info is *** STOP: 0 x 0000007B (0 x F894E528, 0 xc0000034, 0 x 00000000, 0 x 00000000). CAN ANYONE HELP ???????
  • 3 more comments
  • mwmarshall11 Jul 08, 2010
    Did you recently install new hardware, software or change anything with the BIOS?
  • bjones8205 Jul 08, 2010
    No, not recently. I haven't installed any new hardware or software in a while. The last time it worked I was in the process of modifying my router settings. I was using my flash drive to load the files. My desktop has always been running slow but when I to used my flash drive it slowed up even more thats when I decided to improperly shut it off.
    I also use the flash drive for my mac files, can that play a part in problems I have been having with my desktop
  • bjones8205 Jul 17, 2010
    Will I be able to find the correct rebooting software for windows media center on the internet.
  • bjones8205 Jul 19, 2010
    Thanks for the link. Is there any other way I can reboot the computer because it can't seem to find the CD in the drive. I have tried going to the F2 = set up and setting the boot sequence to IDE CD-ROM Device to 1st.
  • bjones8205 Jul 24, 2010
    I had to press F8 in order to boot the reboot Cd. It brought me to the Windows Advanced Options menu. When I try to click reboot the screen will blank for a few seconds and it will bring me back to the screen where it will ask me do I want to start windows norlally, safe mode ,safe mode command prompt. Any more suggestions??????
    President:
  • 2,340 Answers
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
Posted on Jul 08, 2010
  • 2 more comments
  • yaoyang Jul 09, 2010
    To troubleshoot the process will take sometime by trail and errror.
    Since you mention you have Mac files on your USB flash drive, can you check if your flash is clean ie free from any "nasty" files than have a auto inf that might install some unwanted files to your PC and cause your PC to crash? (FYI if you install any Mac programs that is not compatible to Windows on the PC there is always a possibily your PC will crash. Trial Tested on my PC and it crashed.)
    Maybe this workaround might help. Disconnect any devices attached external or internal to your PC. Remove your PC Bios battery(CR2032) and reset it to default and set time to current time. Reboot and see whether you can access to windows? If you can access, then do do a "chkdsk /f/r" from the "Command Prompt". If not,
    Can you boot from your CD/DVD ROM? If your can do a diagnostics test on your Hard drive. You can use the "Hiren's BootCD", or your can download the bootable diagnostics CD from the Hard Disk manufacturer. This is to check whether your HDD is error free or healty.
  • yaoyang Jul 18, 2010
    Microsoft Windows XP Media Center Edition 2005 download, try here http://www.yourbittorrent.com/torrent/15...
  • yaoyang Jul 20, 2010
    When you enter to your CMOS setup, are the devices HDD and the CDROM detected in the Bios settings? If any of the devices is not detected possibilities the hardware is faulty or configuration of devices settings are wrong Check your CMOS battery? Any SATA interface devices? CDROM or HDD? Best is to set your BIOS back to "default" and select CDROM as 1st boot drive. (In some motherboard the "IDE or Native" settings are the same.)
    If your BIOS support USB devices your can boot from a Bootable Flash drive too.
    If you have download any OS from the web, be sure to burn it a low speed, say 4X or most of the time the burnt disk won't boot.
    Rather difficult for me to assisst you 'cos don't know your CMOS/BIOS configurations.
  • yaoyang Jul 25, 2010
    When you press F8, you are entering safe mode only, it seems that your sytem cannot boot from a bootable CD(ie WinXP or any diagnostics CD)? Either your CDROM or the Bootable CD is no good?
    Disconnect the CDROM from the system, reboot and see whether you can boot your system into safe mode? If not.......,
    Most probably in your case your system files are corrupted, If you don't need the data on the old HDD, then I suggest you repartition, reformat and do a fresh OS install on your PC.
Hello i have an HP windows 7 i turned it on and it goes to blue hp screen and freezes up
A blue screen error usually comes up on Windows 7 when there is a serious hardware or software issue that may be causing Windows to Shut Down unexpectedly. At times, a message may also come up on your screen saying "Windows has been shut down to prevent damage to your computer."
To troubleshoot this issue, you may need to try out multiple troubleshooting options to detect whether the issue is with your hardware or software and to resolve the same as per the recommended procedure.
To know more about your troubleshooting options to get rid of blue screen error, you need to refer to the following Microsoft and HP support pages:
http://windows.microsoft.com/en-in/windows7/resolving-stop-blue-screen-errors-in-windows-7
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00372711#N182
The above troubleshooting steps may also help you to resolve the freezing issue. If they don't, please let us know so that we can suggest you additional troubleshooting options for the same.
GuruAid.com
Jul 13, 2014 | Computers & Internet
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
Blue screen
Yes normally if you don't shut down your system properly you get this message, Solution : Log on to save mode and backdate your computer to the day before you got this message. If it doesn't work, you are gonna need to reinstall your O.S.
Feb 07, 2012 | Dell Inspiron 710m Notebook
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
BLUE SCREEN; AutoFocus " UNMOUTABLE_BOOT_VOLUME "
Unmountable boot volume is an error you get when your hard drive is failing. You will need to replace the hard drive.
May 21, 2009 | Toshiba Satellite L35-S2366 Notebook
Blue screen ,technical info,
try reinstalling windows
Apr 02, 2009 | Computers & Internet
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
Blue screen of death
you need to boot from the cd, you have to change the boot senquence to start wth cd rom, when it prompts you to press any key to boot form cd,do that, it will load some files then restart again and the same message will appear, this time don't press any key, just let it continue on its own.
Mar 13, 2008 | Toshiba Satellite P25-S507 Notebook
Microsoft Windows XP Media Center Edition 2005 for PC Logo
346 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
