Question about Sony Reader Touch PRS-600
SONY PRS600 freeze at "Opening Book" screen. Trying hard reset many times, but nothing changed. What should I do next.
3 Suggested Answers
SOURCE: rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Posted on Nov 18, 2007
SOURCE: I am trying to install reader prs600. I have
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PRS600&upd_id=5300&os_id=7
Posted on Dec 26, 2009
My daughter reset the device lock on my prs 600 and does not remember the code. Can it be reset?
Hi jaimbry!
To unlock the Reader you will need to do a "Hard Reset", unfortunatelly this will delete all content on the device.
Here are the steps:
1. Disconnect the Reader
2. Hit the Reset button at the bottom of the Reader
3. While the reader shows 'Opening Book...' press and hold the 'Back' button and the 'Volume Up' (+) both at the same time until reset all appears
4. Once you do that you will get a confirmation saying that all content will be removed icon_e_sad.gif you just tap to accept
http://digialreader.freeforums.org/forgot-4-digit-password-prs600-t8.html
GoodLuck!
eBookBoy
Jul 27, 2011 | Sony Reader Touch PRS-600
When i turn the page on the sony ready touch I can still see the last page under the next page. Has this happened to anyone else?
Hi patsyhodgins!
At certain point this "goshting" you see its normal operation because of the type of screen (E-Ink) but if you get words mixed or its too difficul to read, you can try a reset:
Note: This will not affect your ebooks:
1. Disconnect the reader from the computer
2. Power off you reader
3. Hit the reset at the bottom for 3 seconds
4. Power on you reader
5. The screen will blink and will display "Opening Book", let the reader load your books
See if the problem persist, if so, you can try a hard reset, make sure the reader is fully charged.
Note: This will delete all content from you reader, I recommend you to back uo your data before proceed:
1. Power off the Reader.
2. Press the RESET button.
3. Power ON the Reader.
4. When the screen shows "Opening book..." , press and hold at the same time the "Page Back" button and the Volume + at the bottom until the "Reset All" appears on the screen
If none of the steps above work, then contact Sony to get the screen repaired.
GoodLuck!
eBookBoy
Jul 17, 2011 | Sony Reader Touch PRS-600
It freezes and doesn't charge well.
Hi!
You can try a hard reset to start all over, or probably a book inside your reader may be corrupted. You can try a hard reset:
Note: All data will be deleted and you will need to transfer all your content, if from Sony, do not worry you can redownload the books at no cost again.
1. Make sure the reader is at least half charge (If you are not sure, connect it to the computer for 15 minutes and make sure there is a redlight at the top)
2. With the reader disconnected from the PC, hit the reset button at the bottom of the reader for 5 seconds
3. Release the reset, and slide the power swith, the scree will blink and will shot "Opening Book..."
4. While the reader shows "Opening Book" press and hold the zero "0" and the down arrow until "RESET ALL" appears on the screen
5. You will be prompted to press the number five "5" to agree
6. Press the number 5 and the reader will go blank, turn the reader on again and this time allow it to load
7. Transfer you books again
Hope this helps, Good Luck! =)
eBookBoy
Jul 14, 2011 | Sony Reader Pocket PRS-300
MY SONY EREADER ISNT WORKING AT ALL. THE RESET BUTTON WILL NOT DO IS JOB AND THE ONLY THING ON THE SCREEN IS ROTATING ARROWS.wHEN I CHARGED IT DIDNT TURN YELLOW.iTS BEEN LIKE THI9S SINCE CHRISMAS AND IT IS...
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
eBookBoy
May 16, 2011 | Sony E-reader Portable E-book MP3 Player
My screen is frozen even after trying reset it. What should I do? The battery is fully charged.
hello , since u have tried reseting it , u have to hard rest the devive , follow the instructions below,,
Hard Reset (PRS-600/900)
WARNING: A HARD RESET WILL ERASE ALL TRANSFERRED CONTENT ON THE READER. IT WILL NOT ERASE THE BUILT-IN DICTIONARY.
2. On the bottom edge of the Reader, using the stylus, press the RESET button.
3. Turn on the Reader.
4. While the screen displays Opening book... , simultaneously press and hold down the Page Turn button and the VOL + button until the Reset All screen is displayed.
NOTE: If Opening book... does not display on the screen, charge the Reader's battery for several hours before attempting the reset process again. 5. Touch YES to reset the Reader.
,,,regards ..i hope this was helpfull
Dec 04, 2010 | Sony Reader Touch PRS-600
Have lastest ereader by sony. Can't figure the
Are you referring to the PRS900 or PRS600 Reader?? Please follow the below link to download the manual of the PRS900 Reader.
http://www.docs.sony.com/release/PRS900.pdf
Please follow the below link to download the manual of the PRS600 Reader.
http://www.docs.sony.com/release/PRS600.pdf
Jan 30, 2010 | Sony E-reader Portable E-book MP3 Player
Dec 26, 2009 | Sony Reader Touch PRS-600
The Sony PRS-600 Reader has a well-known screen glare problem. Are there any fixes for this problem? I would think it wouldn't be too hard to just replace the screen's surface with something that works...
The PRS600 Reader doesn't have any settings to increase the brightness and contrast. Howevver, this is not a well-known issue with the PRS600 Reader. You may try resetting the Reader by pressing the RESET button. If the issue still persists, unfortunately the Reader may require service. Please follow the link to get it repaired: http://eservice.sony.com
Nov 09, 2009 | Sony Reader Touch PRS-600
PS3 Screen is blank
No i think your ps3 froze or your settings r 4 hmdi and not snail cables next time reset your tv sometimes the hdmi freezes
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
Address Book Failure
back up ur data, take out ur memory card  & then dial *#7370# for hard reset or contact service centre if problem persists
Oct 04, 2007 | Sony Ericsson K800i Cellular Phone
Sony Reader Touch PRS-600 Logo
512 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
