Question about Maytag MAH6700AWW Neptune Front-Load Washer
It shakes the house... making the walls vibrate.... how can i fix that
    President:
  • 1,382 Answers
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.Check your motor coupling, it is between the motor and transmission,made of rubber and plastic, if it is not broken and you heard a lot of screaching ,i would say it is your basket drive tube-could have gotten worn down on the bottom around the clutch brake area! Better purchase a used basket drive tube,install it with a new clutch and it will start working for you.
Thank you !!
Posted on Jul 08, 2010
    Champion:
  • 274 Answers
Ajust the legs on the bottom of machine and balance it out,they make a plate for the machines that need to mount to the floor.
Washer vibrates madly on spin, feet are level
This usually happens when the load is uneven.
Dec 28, 2013 | Kenmore Washing Machines
2002 a4 avant 1.9tdi los of power started shaking badly esp light comes on stays on
SOUND LIKE TURBOCHARGER PROBLEMS, TURBOCHARGER IS YOUR POWER HOUSE.SHAKING VIBRATING SHAKING COULD BE WORN TURBOCHARGER TURBINE SHAFT BEARING.LISTEN AROUND TURBO FOR NOISES.
Aug 06, 2011 | 2004 Audi A4
Is there an external thermostat that can be used for this and there is a vibration noise, any suggestions?
I'm not aware of a wall thermostat for this heater, because it does not have a Millivolt Control. As far as the vibration is concerned, does it just occur when the fan is on? If so the fan or the fan motor may be loose. Or the fan itself is out of balance. As make sure the fan housing is properly attached to a wall stud or studs.
Feb 14, 2011 | Fahrenheat (FFH1614) Wall Mounted Panel...
Vibrating Front Load Washer
probably not. did you just move in? have you always had it upstairs? the only way to make it so your house does not shake is to reinforce the floor.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Tub vibrates and hits side walls on spin cycle.
Open the top, and look for worn or broken vibration dampers between the outer tub and the cabinet walls. Shake the tub to help locate the problem areas. Hope this helps!
Jan 02, 2010 | Washing Machines
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
Terrible vibration on washer
make sure your locknuts on your pedestal are tightened all the way up
Apr 15, 2009 | Maytag MAH8700AWM Neptune Front Load...
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
447 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
