Question about Car Audio & Video
1997 toyota corolla car radio. CD works ok but no reception from radio. All appears ok in display with channels showing and all channel change/scan functions work but no sound. Sometimes static is audible but mostly just silence
  • 17,130 Answers
First of all have you connected a good antennae. Please double check this out if the antennae cable is shorting with the body ground. If possible use an external antennae wired to the set. If this wont help, then we have definately an issue within the front end of the radio section. Check within the set after putting the mode to Radio for any detecction of EMI. Use a signal injector if you can to trace the signal back from the preamp audio to the radio IF. If you get a response you might have a failed IF processor. Replace if you are able to do so.Initially fix the frequency to the most powerful channel and shake wires or connectors to get a reception. if so solder the area in question.You could also put the Radio on for some time to check for any capacitor electrolitics that have reduced in life/value. I hope this helps. Good day
Posted on Jul 08, 2010
After AIR setting and AUTO SCAN, I cannot even receive local channels 4-5 miles away. What is the problem? See below for details.
There may be a problem with the antenna connection. Channels are not being sensed during the scanning process
Dec 12, 2016 | Olevia Televison & Video
Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
May 19, 2008 | Jensen MSR4050G CD Player
2008 cd player broken no way to code
2008 Toyota Camry CD Player - Discussion on Topix
www.topix.com > Toyota Camry
Dec 10, 2007 - #1 Dec 10, 2007. Just bought a 2008 Camry LE with standard CD player. ... Toyota will repair the CD player tomorrow morning. I still have a CD stuckthat I can't ... Toyota Highlander Radio Problem
Aug 2, 2010
2009 Corolla Stock Radio Display goes Blank.
Jan 18, 2010
2007 Toyota Camry Radio Reception
Mar 17, 2008
More results from www.topix.com
images for Toyota 2008 cd player broken
Oct 21, 2015 | 2008 Toyota Highlander
Toyota corolla professional aerial problem, reception on radio
Some tints have metal in them so it might cause you grief but how is the radio when you wind down the windows ?
A power aerial might fix the problem put in the front fender and then run to the radio via a coaxial cable.
However in my car it was the radio that was the cause of the same bad reception and it worked on one channel only.
I have since replaced the radio but this may not be the cause of your problem and you would want to really know if the radio was the cause before incurring an expense of a new car radio.
May 28, 2017 | Cars & Trucks
Toyota corolla 2004 radio and CD player stopped working same time while driving on the highway.
have you had any speakers or bass boosters installed in your car that werent in the vehicle before you purchased. Watch for wiring issues or possibly even battery voltage issues.
Jul 06, 2012 | 2004 Toyota Corolla
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
Radio channel problems in hot weather
internal failure in radio.. need to send to electronics place or have s]dealer send yours out for repair cost is around 250.00
Oct 05, 2009 | 2005 Toyota Corolla
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
