Question about Gateway GM5045E PC Desktop
Windows/Gateway GM5045E will not discover GeForce 9800GT
I done everything i know. tried three different PCI Express cards and plug and play doesn't discover any of them. they all work in other PC's. Does Gateway have a disable plug and play or in the slot bad...
  • Gateway Master
  • 1,606 Answers
The problem is more likely you don't have plug and play running in windows. To install the UPnP user interface
  1. Open Add or Remove Programs in Control Panel.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the UPnP User Interface check box is selected.
You can also add the hardware in manually. Just treat it like a non plug and play device You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  1. Attach the non-Plug and Play device to your computer.
  2. Open Windows/Gateway GM5045E will not discover GeForce  - shortcutcold.gifAdd Hardware in Control Panel.
  3. In the Add Hardware Wizard, click Next.
  4. Click Add a new hardware device, and then click Next.
  5. Do one of the following:
    • Click Search for and install the hardware automatically (Recommended) if you want Windows to try to detect the new non-Plug and Play device you want to install.
    • Click Install the hardware that I manually select from a list (Advanced) if you know the type and model of the device you are installing and you want to select it from a list of devices.
  6. Click Next, and then follow the instructions on your screen.
Posted on Jul 08, 2010
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
INSTALL PCI EXPRESS USB CARD IN DESKTOP COMPUTER
just plug the card and insert the cd and install it...
May 30, 2008 | Televison & Video
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
Hi! I am running Windows XP 64 OS on a Intel D975xbxlkr motherboard. I need to replace the pci express graphics card. One that will be compatable with the OS and motherboard. I am not gamer Any...
Everything on the Intel D975XBXLKR motherboard is 64-bit. The Processor, and Northbridge chipset included.
The Northbridge chipset handles the Processor, Ram Memory, and high-speed graphics.
AGP and PCI Express is high-speed graphics.
A graphics card plugged into a PCI slot (White) or using Integrated (OnBoard) graphics is NOT high-speed graphics.
The Northbridge chipset for an Intel D975XBXLKR motherboard is an Intel i975X.
(The i stands for Intel)
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
ALL PCI-Express graphics cards are compatible with a 64-bit O/S.
What you may be concerned with, is whether the PCI Express technology used on your motherboard is PCI Express 1.1, or PCI-Express 2.0
It is PCI-Express 2.0 technology that is used.
[Doesn't matter anyway. PCI-Express 2.0 technology is Backward Compatible with PCI-Express 1.1 technology.
A graphics card based on PCI-Express 2.0 technology will work on a motherboard with PCI-Express 1.1 technology.
You just won't get the full capabilities of the graphics card.
You probably won't notice either ]
A recommendation for your perusal;
1) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5639261&CatId=3669
Yes this is a type of gamer graphics card, and I read your requirement.
My argument is the quality for the price.
Even if you do not game your graphics will be superlative.
Excellent graphics on a computer makes a world of difference.
This graphics card will work with a 350 Watt power supply.
Jun 21, 2011 | Intel 975XBXLKR 975X Mainboard...
My pci Express is8500Gt.my desktop is celoren D,1.80Gz.250HDD,ram 1gb. last week i install it and play nsf Carbon,everything is allright.2 days after when i go to turn on my Desktop then i see my monitor...
If your graphics card works on another pc but not on yours then you should try another graphics card on your pc. If it also doesn't work it means it's a problem with your motherboard.
May 24, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
Purchased D-Link PCI Express card for my Dell desktop Dimension E521 and can't figure out if my computer has a PCI Express slot?? please help???
every computer will have at least one pci slot its white in color i insert your card in to the slot and press it tightly and screw the pci card to cabin and insert the cd received with the pci card and install them
Dec 15, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
No video signal
The video card may have a jumper next to it or it need to be reset in bios If you know how at start up prees F1 or F2 or Del one of these will open Bios in the bios menu you will see setup instructions on the side or the bottom follow them and save if you are trying to add a video card it should say onboard or pci slect pci then press esc on your keyboard then press F10 to save settings then restart pc this should work but check the hp website for downloads get the manuel and find out about the video jumpers.
Apr 07, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
Mother board asus A7V8X-LA
then that video adapter IC (integrated circuit ) in the motherboard which is located near the AGP or PCI express slot is in problem just visit the motherboard technician & get replaced that one ..
it will work ...
the cost of it is some what higher i think to repair .....
just once you visit the motherboard technician before you purchase the new board ....
Jul 04, 2008 | Computers & Internet
Gateway GM5045E PC Desktop Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
