Question about Fedders Appliance Air Conditioner Wall
FEDDERS 7D18E2A - WHEN I PLUG IN IT RUNS IN LOOPS
FEDDERS 7D18E2A - WHEN I PLUG IN THE UNIT IT RUNS IN LOOPS AS IT WAS RESETING/RESTARTING, BUT ENDS UP WITH EE ON A DISPLAY. WHAT IS THE PROBLEM. THANKS.
Where is fedders 5000 btu drain plug
If you have a window unit or thru the wall unit, Drain Hole is located under the drip pan at near the rear of the unit. It may be difficult to find if it is clogged. As the clog will blend in wit the hole.
Hope this helps you locate it. Thanks for choosing FixYa.
Aug 24, 2011 | Fedders A3X05F2C Air Conditioner
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Fedders Appliance Air Conditioner Wall Logo
37 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
