Question about E-Machines eMachines Monitor E15T4
Its slowing down and i want to reset everything were i could start off fresh
    Sniper:
  • 72 Answers
Before you reset every thing lets do these steps
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS Please Note to leave a positive note.
Posted on Jul 12, 2010
I have a toro ccr2000 that starts but when I get to the snow it shuts off
Shuts off -I would look for a bare place on the spark plug wire. Slows down and stops under load (snow) then check for a bind in the throttle linkage. The govenor is not opening the throttle as the engine slows down.
Nov 26, 2014 | Garden
Why water comes out slowly?
This can be caused by several problems. The most likely is that your filter needs to be changed. Another potential problem could be that your fresh food side is too cold. There is a water reservoir in the back of the fresh food side to chill the water, if it gets too cold ice could be forming inside it, slowing down the water flow.
Other things to check is water pressure going to the refrigerator, and finally the water valves located in the back of the refrigerator could be starting to fail.
May 30, 2014 | Refrigerators
Why does my snowthrower engine bog down when throwing snow
It should slow down some as it is under a load. As long as it throws the snow far enough no problem. If not the speed governor may need adjusting. Make sure you have fresh fuel.
Jan 16, 2013 | Garden
Nextbook 2 stalls at startup at the Lincoln page, the only way to turn it off is reset. I have reset about 30 times and it won't start. I let the battery run down and recharged over night. Still won't...
It is fixable.Try to insert a new hard drive or take out the old one and connect it to another PC via an esata port to format it and reinstall everything fresh.
Mar 06, 2011 | Computers & Internet
Shaking to the car and motor while breaking, slowing down and just idling at a stop. is there a reset or something to do with a reset? it started doing that after cleaning the battery terminal posts free...
no reset ,ask a local mechanic to have a look as this could be anything or everything and from afar with no descriptions you will appreciate it very difficult to answer
Nov 03, 2010 | 2005 Toyota Corolla
Everything goes extremely slow.
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
My palm centro started going dead with a low battery signal literally overnight. I replaced the battery with a new one, and it still won't stay charged longer than 6 hours. Also the phone is now running...
I've had a Centro for 3 months and its such a let-down. Not only does the other caller find that my voice comes and goes randomly during calls but, like you, the battery started playing-up.
You'll find that a hard reset will bring the battery life back up. Hard reset clears EVERYTHING, so backup. To hard reset, remove and replace the battery while holding down the red, drop-call button until you are prompted to hard reset.
You'll find the battery life is bertter again, at least for a couple weeks...
May 15, 2009 | Palm Treo 500 Centro
Doesn't want to accelerate
check spark plugs wires!!
Jan 21, 2009 | 1996 Buick Skylark
Computer is sticking and slow
HI
All you need to do is to run an Anti-Spyware program on it. Normally it will make it go faster.
Also you might want to try to limit startup programs meaning to get the laptop to start the minimum programs possible.
You might want also to backup your personal files and scrap everything, do a fresh installation.
Hope it works fine
cheers
Nov 28, 2008 | Dell Inspiron 1501 Notebook
E-Machines eMachines Monitor E15T4 Logo
331 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
