Question about Epson Stylus Pro 4800 InkJet Printer
Paper feed sensor cleaning
Thanks for the suggestion...where do I find the sensor and is there anything specific one should do with the cleaning?
Many thanks,
Andrew
  • andrewn Apr 29, 2008
    The auto feed from the tray since this only happens when I am printing multiple pages from a stack
  • 33 Answers
Are you using the Automatic Sheet Feeder, or one of the manual feeds?
Posted on Apr 29, 2008
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
OUr Sharp Al-1551 copier seems to moan when the paper is feeding. Any idea what it might be? Is there anything I can lubricate? Thanks
Hello sir; Is paper come out with wrinkle, I suggest you need to clean up paper feed roller and pick up roller with alcohal, meanwile check it out the paper path have any thing not suppose to be there.
Nov 06, 2009 | Sharp AL-1551CS Copier
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
May 20, 2009 | HP Photosmart 7450 InkJet Printer
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
How to clean the paper feed for brother mfc 7820 multiple jams
It's difficult to said just by typing, you better get your printer services person to clean it for you.
Mar 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ADF problem
Thanlk you for contacting Fixya.
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top? • Is multi feed error detected by paper length when scanning documents with different length? • Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Thanks & regards,
TechSatya
May 28, 2008 | Fujitsu M3093GX Flatbed Scanner
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
Shredder won't shred any more.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Oct 28, 2007 | Office Equipment & Supplies
Epson Stylus Pro 4800 InkJet Printer Logo
164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
