Question about Holmes Products Holmes HASF1304S-UC 12", White 3 Speed, Stand Fan With Bonus Table Base
I have a 12 inch oscillating standing fan that I am having trouble reassembling as I do not have an instruction manual The model number is HASF 1301W and I cannot make this one part fit in order to assemble the fan basket
3 Suggested Answers
Crossedwires
  • 44 Answers
SOURCE: Holmes HASF-99 10-Inch Velocity Blizzard Stand Fan needs reipair
I downloaded the owners manual from www.usersmanualsite.com but did not see how to undo the grill. However if you go to http://www.holmesproducts.com/Fans.aspx (the fans official site) you should be able to ask them on what to do.
Posted on Feb 09, 2008
vibz
  • 178 Answers
SOURCE: Hello. I have a stand (pedestal) Holmes fan,
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Posted on Aug 18, 2011
New Dyson AM09 hot/cool fan does not oscillate
S Adams, return for refund or replacement, sound like plastic gear inside could be damaged or loose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.dyson.co.uk/support/am09/am09-white-nickel/my-machine-is-not-working/my-machine-is-not-oscillating
https://www.dyson.com/support/am0112/am01-desk-fan-12-silver-iron/diagnosis-root-menu/my-machine-is-not-oscillating-am01
Dyson AM 02 Fan not working oscillating feature is broken
http://www.dysoncanada.ca/en-CA/support.aspx
Jun 20, 2016 | Dyson AM09 Hot Cool Fan Heater
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
Internal Part's Guide for Model A0J-1201 fan
there will be a oscillation driving counter wheel present inside it which is made of plastic tat would have got damaged or broken so replace the wheel then ur fan will start oscillating
Jul 28, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Dec 27, 2007 | Dryers
Holmes Products Holmes HASF1304S-UC 12", White 3 Speed, Stand Fan With Bonus Table Base Logo
128 people viewed this question
Top Holmes Products Dryers Experts
Darial Jr Lasaria
Darial Jr Lasaria
Jay Finke
Jay Finke
James Coghill
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
