Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
Replaced belt the blade stays engaged - Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
  • 760 Answers
Check that you have routed the belt correctly. Did you happen to go to the outside of the idler? Also is the belt the correct size requiring the idler to put tension on the belt to drive it Belt should be loose when idler is disengaged.. See sketch:
Posted on Jul 08, 2010
Blades not engaging
Blade belt is basically driven by a electro magnet check for power and ground at the wiring coming out of the pulley assembly at bottom of motor
Aug 04, 2015 | Garden
Deck belt engages but wont stay on
Make sure the belt keepers around the blade spindle pulleys are in place they are designed to keep the belts from coming off the pulley adjust to about 1/8-1/4 inches from the pulley...also make sure the belt tensioner is tight on the drive belt when engaged if it isn't your belts probably need renewed..good luck...
Jun 24, 2015 | Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Blades to disengage
On mower deck there is a pulley that engages the belt to turn blades. Find it, While tractor is shut off check that spring is on the bracket that moves pulley back when disengaged.If gone replace it. If its there, slide bracket back and forth to find out what it is catching on.
Jun 24, 2014 | Mtd Garden
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My pto belt doesnt disengage
have you recently replaced the belt? It might be to short. Also, check the belt tensioner and routing
Feb 05, 2013 | Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
603 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
