Question about Sunpentown WA-1220E Portable Air Conditioner
Compressor red light turns on as soon as the compressor turns on. Does this only mean the compressor is bad or do I have other fix options?
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Dryer is not drying i have to go through four or five cycles. you can see the red light going on and off in the back
By 'red light', do you mean the glow of the heater element or gas burner? Is this a dryer with an electronic control panel, or knobs?
This is probably the 'cycling' or 'high limit' thermostat going bad (or a sensor if it's an electronically controlled dryer). When this thermostat goes bad, it turns the heating element off too soon (because of internal physical wear) and the dryer runs at far too low of a temperature to efficiently dry clothes.
The thermostat is fairly cheap and easy to fix.
Go to repairclinic.com to look up your part. They also have how-to videos for some dryers.
Mar 01, 2011 | Dryers
As soon as you turn the system on, the power light stays on for a few seconds, and at the same time the yellow light close to the video controller component blinks once. For those same seconds, the yellow...
hey there rls
When your Experiencing Problems with the PS3 like this you mainly have 2 options to take, I will go through each one now so you know what to do.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
PS3 Yellow light of death fix
The YLOD - Yellow light of death
The Red light of death
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $30 - $40
Wait time: instant download and repair within 2 hours
I really hope I have enlightened you and you do what is needed to fix your problems with the PS3 and get back to gaming soon as possible
Please leave any comments if you need any further assistance
Best Regards
Peter Fix
Feb 06, 2011 | Sony Playstation 3 (PS3) Console
What do i do for my ps3 is turns on then turns from red to yellow then turns off
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
The YLOD - Yellow light of death/ Red light error
The Disk Read error
PS3 Freeze up Error
Price: averages between $40 - $60
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Thanks for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
Frigerator nor freezer compartment is cooling. There is power
This sounds like it is the compressor relay is bad. It is located on the compressor in a black box. Cheap and easy to repair yourself. IF that does not fix the problem then your compressor is bad. But for a compressor to go bad this soon is really RARE.
repairclinic.com will have the part that you need. The relay tells the compressor when to turn on and off from the theromstat and if that goes bad the compressor just will not run
May 16, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ps3 when turning on green light yellow light flashes red then turns off
this is known as yellow light of death u could call sony for a repair which cost 150$ or fix it yourselve with a video on youtube.
Warning first option means u lose your data
Warning second option requires a skilled craftsman
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Heating & Cooling Logo
83 people viewed this question
Top Sunpentown Heating & Cooling Experts
Steve F
Pete Norton
Michael Youngman
Michael Youngman
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
