Question about Philips Televison & Video
Philips PL7119-C227 19in hotel tv ,,tv has no menu or on screen items no volume bar channel numbers nothing ,,i replaced the micro prosseser and the eeprom,,and the trimmer pod that adjusts the menu,,also replaced the crt board and the video prosseser still the same everything else works perfect i was told theres a transistor that controls that ,, but i dont know where,,can anyone help,,thanks matt
  • MATTHEW SCHUT
    MATTHEW SCHUT Jul 09, 2010
    I HAVE THE MASTER REMOTE,,,THERE IS NO MENU OR CHANNEL NUMBERS ,,YOU GET NO ON SCREEN INFO ,,THANKS MATT
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
You need master remote for that tv.
Posted on Jul 09, 2010
Testimonial: "GREAT SHOT,,BUT I HAVE THE PHILLIPS MASTER REMOTE,,THE PROBLEM IS SOMEWHERE ON THE BOARD ,,THANKS MATT"
  • homer194261 Jul 09, 2010
    i think thats a chip that fall under nowyou need a sams for that from sams to check voltage on that chip
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Hi, I just bought an older model Philips Magnavox from a hotel(Model Number: TL7127C107 Chassis Number: 27B700-7562). The T.V. itself works fine but I can't access all my channels. I did a little research...
sorry, it wont go away, bet ya got it cheap huh(nothing intended by cheap) but the tv hotel mode is telling you that its a special tuner made for just hotels, the only way to get around this is if you can replace the hotel type tuner on the main-board with a normal type tuner, it'll cost more than you paid though.good luck,a friend of mine bought 12 of then at $25 each, boy he thought what a deal, now he's really crying and they didn't tell him,and they won't refund his money
Oct 17, 2009 | Philips Magnavox 27MS343S 27" TV
Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Mar 22, 2009 | Televison & Video
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
Concierge Hotel TV - Volume Control
If there are no chasis numbers on the outside you may want to open the cast and check for numbers there. Then you might be able to google the number and find a manual. some TV's willl enter the menu or rest by pushing two buttons at once on the set. This could change your channel selection however.
Nov 14, 2008 | Televison & Video
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Nov 16, 2007 | RCA F31672ET TV
How can i get my tv to stop automatically changing to menu screen?
slapshot,
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Nov 14, 2007 | Televison & Video
Televison & Video Logo
566 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
