Question about Refrigerators
My refridgerator freezer stopped freezing but when I turned the knobs to cooler the fridge kicked on and it worked fine for about a week. It then did the same thing. I turned the knobs to cooler and it kicked back on and is working fine. This also includes the refridgerator side.
    Habit-Forming:
  • 75 Answers
I got a fridge have the similar problem,the upper part is cold ,the lower part is almost nothing at all,i found out the problem is ,the upper part is sharing th ecooling system to the lower part ,and the porblem is the passange is block by ice,so the cool air cannot get into the bottom part,clean the ice completely and check it again,remember it ,don't turn the fridge too cold,it helps not happened again for my case.good luck for u
Posted on Jul 08, 2010
Fridge is freezing food fan seems to be running all the time
sounds like you may have a stuck freezer control.try bumping that knob with the back of your fist,if it stops,that is it.if not it still may be the problem.let cool down in freezer for 10 min. open freezer door and turn knob back to off very slow,if it kicks off just at off ,control most likley bad.
Apr 16, 2014 | Frigidaire Refrigerators
Refridgerator and freezer running warm
Your temperature is probably set to high turn it down to about 4 for a couple hours and then back up like 7 dont turn both controls up all the way or it will freeze up on you. You could even unplug it for an hour and let it thaw out then turn it back on the freezer to 7 and the fridge like halfway or a little more than half.... see if this works for you...........Have a good week end! : )
May 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Viking Imperial Fridge... Purchased in early 90's
what is the stat set to ? A common problem with bottle coolers that work the same way, is people turn the stat to high ( very cold). This then drops the evaporator temperature so low it freezes up, in turn this stops the airflow and the ice build up worsens until you get the result you have, a warm fridge due to no airflow at all. It could be short of gas as this can cause it. A faulty defrost heater / timer can also cause it if its fitted as can a faulty fan that stops spinning. Due to the age of the unit I would try turning the stat back to 3/4 and see how that goes. it will get cold but will be more gradual, but hopefully shouldn't freeze up.
Mar 19, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Jan 24, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Bosch Cooler is broken
im taking it that the cooler you refer to is actually a general fridge. if its not working, it is either your th/stat which has not reset or if not, assuming your fridge is an auto defrost, look behind the freezer and locate the timer. you should see a plastic knob plus/minus in the middle of the timer. turn the knob and listen if refrigerator comes on. if not call a tech.
Feb 20, 2007 | Bosch KIL24443 Top Freezer Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
