Hp 4015 telling me got a error code of 68.2 staorage write fail please help
Reemplaza el DC controller.
Posted on Sep 08, 2010
WHAT IS HE SERVCE CODE PIN #. OR HOW DO I GET INTO THE SERVICE MODE
hp LaserJet P4015: 05 4015 08
hp LaserJet P4515: 05 4515 08
depends on which model you have, choose the correct code above. These are the HP numbers but I do not think that Troy changes them when they install the MICR upgrade.
May 29, 2015 | Troy HP Laserjet 4015 4515 Micr Toner HY...
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
50.4 fuser error 4015 laserjet
Faulty fuser..Remove back tray, take out & resit fuser assembly properly, observe that fuser lock are clicked or not,if you feel seated properly, switch on and shoot print command.. If its printing well then you are in in safe side, other wise replace fuser assembly just little bit expensive...
Feb 02, 2012 | HP Office Equipment & Supplies
Morning printer read error 57.04 this is hp laser jet p 4015x
57.04 ERROR means that Fan FN101 has experienced an error (Fan FN101 is at Left side, toward the rear)
To continue turn off the printer and then on
HP recommends the following steps for trouble shooting: -
1.Inspect fan FN101 to determine if its rotational movement is being obstructed.
2.Verify that the fan connection at connector J64 on the power supply PCA is securely seated.
3.If the error persists, replace the fan
HP 4015 Service Manual
Refer Chapter 7, PG-286 for additional details
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Office Equipment & Supplies
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
How to solve error 4900ff on hp 4015 printer
Thank you for contacting FixYa with your printer inquiry.
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
  1. Turn the Machine on.
  2. Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
  3. Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Oct 04, 2010 | HP LaserJet P4015N Printer
I have a HP laserjet 4015 and it shows a 49ff04 error.
TF
Jun 17, 2010 | HP Laserjet P4015x Printer
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
May 19, 2010 | HP LaserJet P4015N Printer
201 people viewed this question
k24674
jasbo
jasbo
