Question about Garden
I have a troy bilt garden-way tiller TH-1019 its about 25 years old or more i have a flat tire but i need to get the whole thing off how do I do that
Loringh
  • 185 Answers
SOURCE: need a repair manual for troy bilt tiller
Ddavis:
Have a look on ebay. Do a search for troy bilt tiller manual. There are several folks on ebay that collect and sell on manual on all kinds of stuff. I was able to locate a manual for an old singer sewing machine.
Hope this helps Good Luck Loringh please leave me a rating Thks
Posted on Nov 11, 2008
  • 109 Answers
SOURCE: 12.5 HP Troy Bilt riding garden tractor. Battery
There is also a safety switch on the brake pedal, it could also stop the mower from starting
Posted on Apr 26, 2009
  • 57 Answers
SOURCE: replace drive belt
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
Posted on May 15, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
I have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
May 03, 2010 | Troy-Bilt Pony Garden Tiller
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
My troy built is several years old and recently the tires went flat. I know there is a transmission disconnect but the only manual I got with it was a Briggs and stratton motor guide. I never paid...
There is no actual transmission disconnect on the mower. If you put in neutral the belt would need to slip on the pulley in order for it to be pushed or roll freely. This usually doesn't happen.
Apr 10, 2010 | Troy-Bilt Pony Garden Tiller
Garden Logo
583 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
