Question about Western Digital Caviar (wd800lb) 80 GB Hard Drive
Western Digital unusual click
I purchased a Western Digital 120 GB HD about three months ago and since I got it the drive it has been making a clicking sound.  The drive clicks randomly and the system sometimes pauses for a brief second (very annoying during games).  The drive has been running fine with the clicking noise for practically three months straight and I've tried the Western Digital diagnostic tool countless number of times and it has always come back clean. I've tried several suggestions by WD's tech support without success.  Anyone know what could be the cause of such a problem and how or if it can be fixed?  I was also told by someone that WD will not replace the drive unless I have data errors (true?).  Any help would be appreciated.  Thanks. Below are my system specs (incompatibilities?): WD1200BB Hard Drive Abit KX7-333 MB AMD Athlon 2000 512 MB Samsung RAM Sony DVD+RW NVidia Geforce 4 Ti4200 Soundblaster Audigy Standard NIC Card My drive is WD800 EIDE 7200 rpm. After 3 month of "average" use one day after being on about 8 h the drive began suddenly making the annoying clicking sound. The machine did not react any keyboard actions. Shortly after that the display went the famous WinBlue with mystic error codes and "began to copy RAM". But no more happened. I was shocked! Has my invaluable pictures and documents went in the bit black hole!?? I put the power "hard" off. Then I put the power on.... and the drive began to make clicking sound immediately. But it stopped and the machine began to load but stopped to the point of "boot from CD/DVD". ARRRGGHHHH!! So I put straight the "System Recovery Disk" into CD-drive. I loaded the whole Win XP and the SP2 and the supportive security programs (AVG, ZoneAlarm, Spy...). After that I run CHKDSK, Smart Disk Defragment (deep scan) by IObit. When running the later one I noticed that my drive file fragmentation was incredible! I have not run the disk defragmentation program regularly enough. I run it through for four times. After that I started the machine 10 times (cold from the button in front and warm from the back switch). I run continuously cocktail of disk active programs continuously in 12 h periods. In that "trial" the drive caused three times the clicking sound ending to the WinBlue screen to WD (tm) Click And Down- action. In that case the machine required warm boot. The click began irregularly times but fewer times after every startup. I put the machine in 24 h duty. The drive click vanished after 2 days! Analysis: Perhaps the fine Liquid Bearings of the drive need to be "run in" to began to work properly - AT LAST!! Echo007 P.S. I have had WD-drives for 20 years! I have never had any problems with them until this case.
  • Echo007 Apr 23, 2008
    Thank you!
    I am most pleased to get such a comprehensive and elegant answer to my irritating problem. I am "happy" now. I have lowered my WD800 drive to slave disk rank - heh. Little bit regrettable because WD800 is otherwise fast and quiet(!) drive. I have began to defrag and backup my drives and data periodically as You told. It may be so that trough disasters and other thumbligs man learns!
    Echo007++
Western Digital hard drives ****!! Ive been through two so far and at over 150.00 a pop, they are ripping people off with thier cheap *** design and slow performance of a hard drive!! I would recommend going with a different brand of hard drive, but not a WESTERN DIGITIAL piece of ****.
Posted on Aug 29, 2008
    Sergeant:
  • 202 Answers
Hello Echo007
I read through all your accounts and following is my conclusion.
I think you have a flakey drive and that eventually the "clicking", or worse, will return. A clicking sound eminating from a hard disk drive bodes ill wind - it is not normal. Even if it does turn out that the bearings needed a break in period, that is, at the very least, bad design as it puts your valuable data at risk during this period.
It's true, WD will require a hard failure of the drive b4 you can get them to replace it. Unfortunately, failures often begin w/ intermittent problems. And intermittent problems w/ computer-related equipment (any electronic equipment, in fact) are the hardest to pin down.
It could be a heat related problem where, once the drive reaches a certain temperature the problem goes away. That's still indicative of some component inside the hard drive that is borderline functioning or a circuit, device or component that is fractured in some way and closed when there is sufficient heat for the metal parts involved to expand enough to complete the circuit or make the contact.
Here's what I recommend:
1st and *MOST* importantly: Set up a redundant backup system for all of your valuable data. Never ever put all your apples in one basket when it comes to hard drives or any dynamic media like a hard drive. Hard drives are made up of both electronic and moving parts - both of which are subseptible to inevitable failure. Unless you're burning your data on a regular basis to DVDs or backing up to tape or some other permanent storage type, then you must employ redundancy in order to protect your valuable data. (Backup to two or more locations.)
2nd: Backup all of your data off of the hard disk drive you're having trouble w/ (and onto one on which you've never experienced problems). Then, run hard disk drive "burn in" diagnostics on it - intensely exercising it over a long period of time (at *least* 24 hours - more if possible - or until a hard failure of the hard disk drive is induced). This will require exclusive access to the computer the burn in is being run on. (You won't be able to use the computer for anything else during this period.)
Include in the hard disk drive "burn in" write and read and seek excercises. The idea is to make the drive break. It will eventually. We just want to make it happen now while it's in warranty. You won't be violating any warranty, etc. by doing this. The drive *should* be able to w/stand any intense burn in routines you can throw at it.
If it still won't fail, I still wouldn't trust it. I'd use it for temporary storage but not for any critical or permanent storage.
You can download Bart's Disktool 1.2 HERE. You can also download Ultimate Boot CD (UBCD4Win) for Windows from HERE, and Ultimate Boot CD (UBCD) from HERE. Each include hard disk drive diagnostics.
If you'd like assistance w/ any of these processes, tests, creating the boot discs, etc. just us know. We'll be happy to help.
Thank you
BJ @:)
Posted on Apr 18, 2008
  • B Joan Rapier
    B Joan Rapier Apr 22, 2008
    Hello Echo007
    I'm hoping you've been able to resolve the issue w/ the hard disk drive in question. I know how difficult these intermittent problems are to pin down.
    I want to thank you for using FixYa and invite you to come back anytime you have questions or need assistance w/ any of your technology gadgets or appliances. We're here to help.
    Thank you, too, very much for the FIXYA rating! :)
    Have a beautiful day
    BJ @:)
WD1200Bevs data transfer
The cheaper the less reliable. Pretty much all the same.
Apr 05, 2014 | Western Digital Scorpio WD1200BEVS 120 GB...
I bought a "My DVR Expander" to use with my DirecTV HD DVR. Does Western Digital make this expander in anything larger than 1TB? If so, where can I buy one?
Note that your DVR will treat this as "extra" storage, i.e., supplemental to its "internal" storage.
A 1 terabyte hard drive allows you to record:
  • Up to an additional 600 hours of Digital TV
  • Up to an additional 120 hours of High Definition TV
Since the largest EIDE/PATA disk-drive is 0.5 TB, the disk-drive inside the Expander must be a SATA disk-drive.
So, disassemble the unit, disconnect the SATA disk-drive, and pay about $300 to buy a "2000Gb Western Digital Caviar RE4 Raid Edition 7200RPM 64 Mb Cache 3.5 7200RPM 64 MB Cache SATA Internal HD 3 Yr Warranty WD2003FYYS".
Connect the disk-drive to its interface.
Close-up the case.
Connect your "custom" PVR expander to your DVR,
and see if your DVR will recognize the 2TB of disk-storage.
Sep 08, 2010 | Western Digital My Book Essential Edition...
Where can you purchase a new casing for a Western Digital 120 Gb Passport portable hard drive?
If your portable Hard drive is in waranty then I suggest sending it back to them stating the problem.
Oct 20, 2009 | Western Digital Passport 320GB External...
Western Digital 120 GB Model WD1200U017.002 SN WXE0o6620867
1.I will suggest you please partitioned it properly.
2. Check your Registry. Some times people use to FIX Registry for Reading multiple Partitioned External Drive.
3. You must require partition.
4. Have you check the cable which was supplied with the HD. As other cable may not support properly.
Enjoy
SQE
Jul 21, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western digital my book 500 gb
Cheek your system os is not suportion the hard drive increase the ram and try in xp only
Jul 10, 2008 | Western Digital My Book Essential Edition...
WD 120 Gig HD
There is usually only one light on the drive, which indicates that data is being read or written when the light is light.
Jun 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Apr 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
Western Digital 120 GB Hard Drive
Well usually external hard drives are just a regular hard drive in an encolsure! You can try to mount the hard drive to a regular pc using the ide/sata connector(Im not real sure which interface your drive will use). From there you can tell wether its the actual drive that is giving trouble or just the USB enclosure! Most of the times with those name brand external drives its a lil complicated to figure out how to take it apart to take out the hard drive. What you can also do is try(if you get it open) to see if you can unplug the hard drive from the enclosure then power on the enclosure and see if the lights come up green(or whatever color it uses to indicate ready)! if it does then power off the enclosure then re-connect the drive to the enclosure and power on again! Maybe that works! Removing the drive might void your warranty, proceed at your own risk! Good Luck regards, babb
Apr 30, 2007 | Western Digital (WDXU1200BBRNN) 120 GB...
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all Western Digital Caviar (wd800lb) 80 GB Hard Drive Questions
Western Digital Caviar (wd800lb) 80 GB Hard Drive Logo
930 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
