Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi 31cc 18'' 790r ez has no power
Replaced fuel lines (fuel filter), spark plug, air filter. new gasoil (using 32) but recommends 40, should not make too much difference.
Primer bulb has a small crack but still pumps, (not sure if this cause problem) Exhaust gasket resistor is broken (no screen) but took muffler off, when trying to start. same problem.
starts ok, but has zero power when throttle is pressed. Rebuilt carb with kit (walbro) Set the H, L to 1 1/2 turns from full closed position.
Trimmer was not used for a couple of seasons.
Any ideas what might be causing this.
R
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
You have done just about all you can do with this machine give up and buy a new one
Posted on Sep 03, 2010
My Gas Powered Ryobi String Trimmer (RY26500B) won't start. What should I try??
Here are the basics. You need: spark, fuel, air, compression, and timing to make it run. Clean the spark plug. Inspect the fuel lines. Are the hard/brittle? Do they connect to the filter in the gas tank? Clean the air filter. When the spark plug is out, put your finger over the opening and gently pull the rope. Do you have compression?
Most common repairs needed are usually fuel lines and carburetor work.
Aug 20, 2010 | Ryobi Garden
Craftsman chainsaw 18" 42cc doesn't start
Remove the spark plug and test for spark. If nothing, try a new plug set to 0.020" gap. If ok, put a small mount of fuel mix in the plug hole and try to start. If you get several pops, then check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for rot or damage. Make sure to use fresh fuel premix (40:1) using modern synthetic saw oil in it's own can and shake thoroughly just before filling each time. If you got no spark in the first test, expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and check for spark. If still nothing, replace the module using a thin business card for a gap gauge between the module poles and the flywheel magnets. If you did get spark, then investigate the ignition switch and wire for possible grounding. Hope some of this helps!
Jun 24, 2010 | Ryobi Factory Reconditioned 18" 40cc...
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 | Garden
Engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
May 14, 2009 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
779 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
