Question about Kolcraft Ultra Light Vibes 18275 Crib
Where do I find a bassinet replacement canopy for my
Where do I find a replacement canopy for my bassinet or the rod to cover on my own?
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
How do you take off the bassinet cover for the top part that is like a canopy?
If this is for a bassinet here is the answer I posted for another person. If not, just let us know.
We will see what we can do for you.
Many bassinets have rivets that dont allow you to remove the fabric.
We draw water in the washer and add soap then drop one end in
and work it around until it is in the washer. Use gentle cycle and
cross your fingers that no damage is done. I have washed many of them
and never destroyed one. Good luck
Feb 23, 2011 | Delta Luv Angelina
How to take apart fisher price soothing sounds bassinet to clean. I want to take the basket part & canopy to wash. I can't get it off the rod.
hi
i'm not sure if this link is the correct bassinet but it may help pg 12 is washing instructions
http://service.mattel.com/instruction_sheets/79359pr-0920.pdf
try a reversal of the putting together push the silver buttons in when you locate them on the frame
i must say though i'm not sure it can be disassembled
Oct 20, 2010 | Fisher Price Baby Gear
Bassinet canopy
You may be able to order one through the shop you brought it from or you can use a net curtain which may be cheaper
Feb 12, 2009 | Eddie Bauer Musical Rocking Bassinet...
We have a baby snoopy bassinete and need a new ******** for it
I was given a baby snoopy basenette and its in good condition however the craddle part slides side to side if you move it, is it supposed to be that way, also i took the covers off to wash them and i cant figure out how to put the canopy back on theirs two bars, a thin one and a thick one, which one goes in the front where the ruffles are?
Nov 29, 2008 | Delta Enterprise Snoopy Deluxe Crib
How do you take the covers off
there are two screws on the sides, you might want to unscrew them, after you do so the thin bar should snap off if u give it a little tug..then you can remove the canopy and the rest of the covers..make sure you remember how it looks before you take everything off..because it could be trick putting it back together, thats my problem now i cant remember how the canopy gpoes back on...?
May 29, 2008 | Delta Enterprise Snoopy Deluxe Crib
I have a 3112doh Winnie the Pooh bassinet
I could not get the fabric off my canopy either. I found it slide nicely into my washer (top loader with agitator) even with metal insert. I washed on delicate and it came out great, with no damage to canopy.
May 29, 2008 | Simplicity for Children 4-in-1 Convertible...
CANOPY
return it to the store it was recalled Aug 31, 2008 for strangulation hazard as two babies died from this thing
Mar 10, 2008 | Simplicity for Children 4-in-1 Convertible...
Graco bassinet model 3300
http://www.babyage.com/icons/localhost/products/multimedia/10186_RocknRollBassdir_12_17_03.pdf
Dec 01, 2007 | Graco Simplicity Rock n Roll 330 Crib
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
Kolcraft Ultra Light Vibes 18275 Crib Logo
326 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Jennifer Rock
Jennifer Rock
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
