Question about Ovens
My ovens on zanussi zce 7700x wont activate and work the digital display clock is not illuminating so therefore the top and bottom oven wont work
  • 1462 Answers
SOURCE: oven fan
almost certainly a problem with the fan and motor. try moving fan blade with a small screwdrriver thro the holes in the back panel to see if it is jammed. after that you are faced with removing appliance, remove back panel and check motor continuity
Posted on Apr 22, 2007
SOURCE: the clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
  • 116 Answers
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
If the oven was working before then
1. Power is gone from the unit - loose connector or neutral wire ( or ground wire depending on wiring system being used)
2. The power supply transformer (or transistor) on control board is busted. This is especially true if there was power problems in the apartment- power going on and off frequently. Check the wiring and see what comes up. Hope that helps
Regards
Posted on Sep 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi electric oven ZBM 762X How do I trun the oven to manual?
If it is an anologue timer then rotate the knob until you see a hand symbol in the window, this brings it off auto.
If it is a digital timer then you need to press two or more buttons at the same time to get it off auto and back onto manual.
Posted on Dec 08, 2008
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Zanussi 7700x help
If you try the oven ,and everything seems to work o/k, then I would conclude that it is an earth wire that is disconnected.
In itself it will not effect the oven , but it does need to be connected to a convenient earth point or ground as it is sometimes called.
If the oven or one of it's functions does not work, then it is obviously anwire that controls something.
Plz rate my comments.
Thanks,
Jan 19, 2009 | Zanussi ZHQ575 Electric Double Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi oven wont work. clock flashing 'auto'
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
Oven fan
Apr 21, 2007 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
