Question about Polaroid FLM-2011 Television
Input setting I have a model FLM 2017. Every time I turn it on, I have to change the input setting to get a picture. This is a recent problem, with no obvious cause. Is there a way to fix the setting so I don't have to change it each time I use the TV?
  • carolzorn May 30, 2008
    My polaroid has no picture, only sound, when I first turn it on, a pictures comes up for only a second, and then goes black........it is under a year old
    Genius:
  • Polaroid Master
  • 1,667 Answers
When you turn off the set, are you turning it off by running the power through a cable or satellite box? If you are shutting down the set from the AC mains side the set can lose all of its user set-up. In most TV models, the main power supply must have the AC mains connected.
The power supply goes in to a standby mode when the TV is turned off by its own power switch (not by the AC mains). The supply puts out enough power to keep the uPC and the user memory active.
If the set is properly turned off and it is losing its user set-up, it is possible that there is a fault in part of the uPC circuits. Depending on the model of set, there may be a lithium battery, or memory capacitor, or an EEPROM for keeping the user set-up memory.
Jerry G.
Posted on Apr 18, 2008
The picture size resets when the tv is turned off then on.
It also resets when you switch to a different Input... IF you have the Auto Aspect Ratio set to On! To set the Picture Size so that it won't change back each time, switch to the Input you wish to change (you'll have to do this for each Input separately), then go to- MENU > Picture > Theater Settings > Auto Aspect Ratio > and set it to Off. Once you've done this, your Picture Size setting will remain, even after powering off, or switching inputs ;)
Oct 23, 2010 | Toshiba 32E200U 32 in. TV
I'm trying to use a Polaroid FLM-3201 as my computer monitor. The screen resolution is poor, so I have tried to change the settings in the control panel. However, when I do so the Tscreen goes to snow and...
use manual settings for this input. i've had this issue before. when trying to watch movie from netbook, similar message occur. got to manual phase settings, played with adjustment and: ta-da! got good picture. sometimes auto mode for this input is not catching up.
Good luck,
Alex's TV,
Philadelphia, pa.
215-806-5980.
Feb 22, 2010 | Polaroid FLM-3201 Television
My Polaroid FLM-3232 does not display over air HDTV channels
There is no such thing as a 'digital antenna;' any antenna with sufficient gain and bandwidth will receive whatever signals there are available.
You may have to change the input source via your set's menu so it is looking at the antenna input; it may be set to cable currently.
Feb 03, 2010 | Polaroid FLM-3232 Television
Turns on but no picture
connect the chords corrrectly.change the tv input to corresponding mode and try again.
Sep 11, 2009 | Polaroid FLM-3201 Television
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid flm 2017 turns on then goes black sound still works
This problem is often replated to a leaking power supply capacitor on the secondary side of psu rated at +/- 2000uf at 12v...yup 4 bucks should do it...the hardest part is often opening the power supply up screws are often located underneath rubber feet....never make contact with the primary ac supply side even after it is unplugged reservoir capacitor high voltage can store a charge for long time and be dangerous to contact.
Dec 13, 2008 | Polaroid FLM-2011 Television
No Sound ... (main input module) ?
the module itself is 56.00 dollars then the labor to install, its hard to find the seperate components the factory has set things so that you have to buy the whole control module to replace one part or board. try and find that component on e bay or used some where thats your best bet to fix it.
Dec 17, 2007 | Polaroid FLM-3225 32 in. LCD Television
Polaroid 3232
i have found others that they did this same symptom when the ir board went out its only 9.95 plus installation.
Dec 11, 2007 | Polaroid FLM-3232 Television
HD cable question
i have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
Dec 03, 2007 | Polaroid FLM-3232 Television
Polaroid FLM-2011 Television Logo
178 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
