Question about GE Energy Star WCVH6260F Front Load Washer
How do you clean the door gasket? It has black stuff on it.
    Champion:
  • 274 Answers
Once a month bleach machine out and clean out soap and softner dispenser,so lets start cleaning you are going to need a powerful-pool shock and put 1/4 of the bag in the soap area,you well need to let it soak for 24hrs. cause you have mold in every inch of the machine.Now run the machine on cold water.After machine has gone through all cycles.Open door you may need to clean door seal with a old tooth brush,and you may need to lift seal to check underneath.after seals are clean and dispencer is cleaned were dispencer goes make sure its clean as well. after use always keep door open and dry out dispencer after each use.always use a 1/4 of a cup of clorox2 for HE. and clean machine out this should stop ths problem.
Posted on Jul 08, 2010
Remove black stuff from gasket
Sou8nds like you need a replacement r gasket. I would suggest taking it to a properly qualified and licensed repair technician (at their premises to reduce costs) and have them do a full and complete service that includes checking and testing all seals and gaskets. The reason for this is because if it's old enough for one gasket to be shot, then chances are the others will need replacing as well.
Nov 10, 2013 | Kenmore Dishwashers
Tip
How to maintain your refrigerator door gasket.
One of the most common problems with a Refrigerator is the door gasket torn and falling off.
I can't tell how many homes I have been in and seen the door Gasket on the Refrigerator falling off, especially at the bottom. Its a very simple
maintenance remedy that most do not think of or have ever done.
What happens almost always is that sticky stuff (syrup,jelly.cokes,
orange juice,etc. spill down on the lower door and gasket and then dries.
Guess what? When you open the door the gasket is stuck to the fridge
and it pulls the gasket a little each time until it pulls off.
Its very simple ,once a week or so to take a warm wet rag and clean
the gasket all the way around and also the ref base then gasket seals to.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
on Aug 31, 2010 | Refrigerators
Have black oily film appearing thru out the
I have had a similar problem on a Bosch. Don't know where it comes from, except to say the bottom door gasket appeared to be melting for some reason. I replaced it with a new one, and no signs of melting after about 3 months.
I was able to clean the black smudge from various parts of the dishwasher using Berryman's Chemtool, a carburetor cleaner available at the auto parts store. Use in a well ventilated area. Am certain naptha or other cleaner would work as well, but again, use sparingly and with plenty of ventilation. Rubbing alcohol would not cut the stuff.
Let me know what you find.
Dec 16, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Referator doors are hard to open
When you shut the door there is a vacuum occuring and causing the doors to be hard to open. Take someting like a popcicle stick, break it in half and put them together, one on the other and tape it to the gasket at the bottom of the ref side door. This will make a vacuum break and should make the doors easier to open. Also, make sure your gaskets are clean, no sticky stuff on them or the frame.
Dec 18, 2008 | Whirlpool Refrigerators
Changing door gasket on Servis M9813s washer dryer
you can clean in situ just as good as if you remove it
Jul 12, 2008 | Washing Machines
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
GE Energy Star WCVH6260F Front Load Washer Logo
229 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
