Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Dishwasher door spring repacement - KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
  • Anonymous Nov 26, 2008
    broken door spring
  • glaursen Jan 14, 2009
    The door springs on my KitchenAid dishwasher need to be replaced. Is there a manual that shows how to do this yourself?
  • 258 Answers
I have just done this on my dishwasher and post pictures and a solution here:
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 17, 2009
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
Dishwasher door won't latch
it is very likely the dishwasher is not levelled correctly or the springs in the door are too tight. Refer installation manual to check dishwasher levlelling and door spring is adjusted correctly. Please provide dishwasher make and model if you do not have the installation manual.
Aug 29, 2012 | Dishwashers
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
Door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
Nov 23, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
157 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
