Question about Windchaser PAC8 Air Conditioner
Recharge pac 8 windchaser
How do I recharge this unit. I think it should be colder.
Need a manual for a Windchime PAC9 Model SA 12059 Air Conditioner, or advise on how to bet alarm light to turn off so unit will work
on the WEB
Windchaser PACR9S Instructions Manual - ManualsLib
www.manualslib.com > ... > Air Conditioner > PACR9S
View and Download Windchaser PACR9S instructions manual online. WindChaserProducts Inc. Instruction and Maintence Manual Portable Air Conditioner ...
Aug 04, 2015 | Windchaser Heating & Cooling
Can u recharge model SG-PAC-08E3
You can recharge any type of AC unit. First you must find out where the leak was and repair it. Then you need to pressure check it with nitrogen and leak check it to make sure there are no more leaks. You'll then need to pull a vacuum of 30 inches of water and then charge the unit with the safe refrigerant that came out.
May 16, 2015 | Heating & Cooling
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Do I need to recharge coolant once in while?
Under normal conditions, refrigerant or freon need not be recharged or replenished. Refrigerant is contained in a "closed loop" that consists of a compressor, expansion valve, evaporator coil and condenser coil. If a leak developes as a result of damage to any of these components, the refrigerant will escape as it is under pressure. The leak will need to be located and repaired before refrigerant can be returned to the system. An unsufficent refrigerant level is always an indication of a leaking system, but; an A/C unit that fails to cool the air is not always a sign of a low refrigerant level.
Aug 05, 2011 | Windchaser PACR10000 Portable Air...
I need to get an exhaust kit and the adjustable part that goes in the window. Model PAC 9 Any idea where I can get this so that I can use my unit?
Sadly the company is out of business, so you will have to get a little creative like I did. I got what I needed at lowes, some flex duct, a pvc pipe fitting, small metal brackets, zip ties, thick foil tape, a piece of plywood for the window part, and some paint. Good luck.
Jul 12, 2011 | Windchaser PAC9 Air Conditioner
What is a bottom blower? No bum jokes, please! I think it's something to do with engineering, but not too sure.
the bottom blower in a PAC9 is the blower motor that sucks room air in through the bottom vents of the unit through the condenser. this air removes heat from the condeser and is blown out through the warm air vent duct. A common failure on windchaser units is the 'bottom blower squirrel cage' which is a plastic fanblade.
Jan 04, 2011 | Windchaser PAC9 Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Windchaser PAC8 Air Conditioner Logo
175 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
