Question about Magic Chef Kitchen Ranges
MAGIC CHEF MODEL 38HK-6TXW, SERIES 48 i THINK IT IS; PROBLEM IS TOUCH BUTTON (s) STAY PUSHED IN WITHOUT FUNCTION? aNY iDEA'S? THANKS FOR YOUR EFFORT.
    Champion:
  • 274 Answers
Try unplugging it first and see if that resets the controlls
Posted on Jul 08, 2010
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
Magic Chef Oven intially was beeping and indicating --F0 default code
Hi tjsolutions2,
The function key stuck, that's the F0 error code means. To fix this, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
May 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic chef stove model # 6898VRA keeps setting off alarm f1 why?
Have you tried to Turn it OFF and then Turn it ON.You could also try Pushing Multiple Buttons, if that could help.
If not, i am afraid that this is a BAD CONTROL BOARD / TOUCH PAD error. You need to replace either or both of these. Once done, it would Fix the Problem.
Some Models do Incorporate Touch Pad and Clock Control as One Part. So, that means you Could have Bad Clock Control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Magic Chef CER1115AA Electric Kitchen...
F-7 and beeping is occurring on my Magic Chef,
Hi sixgunromeo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 05, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Model 68HK-6TXW...temp on he electric range will not go above 250, no matter where it is set. Ane ideas on where to check or where to go from here? Thank you don
some ovens have a centigrade/ celcious (sp) and f. check the owners man. for that, to switch back to F.If that's not the case then it sounds like you are only getting 110 vac instead of 220 vac. check breaker, then wireing.
Nov 10, 2009 | Kitchen Ranges
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
Kitchen Ranges Logo
119 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
