Question about Muratec F-300 Fax
CAN I PRINT THE MEMORY FROM ONE MACHINE TO ANOTHER
THE DRUM WENT OUT ON ONE OF MY MURATEC F-300'S SO I WANT TO SEND THE STORED FAXES FROM THAT MACHINE TO ANOTHER F-300 THAT CAN PRINT IS THIS POSSIBLE?
No, take the drum from the good 300 and put into older one just for printing out
then return good drum back to good machine
Posted on Oct 02, 2008
I just replaced my Muratec F-305 drum DK 203OUS with new one and the red warning dot comes up and says "Drum near end" with the new drum. What is wrong?
Yes, the display was saying "drum near end"....it was not saying to replace the drum,... you only replace the drum when it says "replace drum"....right now you have b;own the fuse in the new drum because you replaced it TOO SOON. You will have to find someone to replace the mini-fuse in the drum cartridge...it will still be ok...but soon you will not be able to print on the machine,,,READ THE USERS MANUAL.
Nov 16, 2010 | Muratec F-300 Fax
Muratec F-110 fax machine can send faxs but does not receive, i tried different phone lines, changed configurations changed toner, drum. nothing seems to work thanks, rick
Make sure the machine is in Fax mode and NOT Tel mode. Other thing to try is to pickup handset and listen to see if you hear "Dial-tone" from the line...if you don't then you have probably lost part of the NCU pcb in the machine.
Oct 05, 2010 | Muratec Office Equipment & Supplies
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
How do you reset memory board for muratec f-320 . I am trying to get rid of an error message"Replace drum unit printer not useable". Installed new drum unit and still gives the same error message.
Before doing complete Memory clear try the following...
Press..PROGRAM,*,*,I(thats the letter I),then ENTER.
That should reset it. Only replace the new drum into the machine when the machine says "Replace Drum"...NOT when it says "replace drum soon".
As a last resort a complete memory clear is PROGRAM,*,3.....but be warned this will clear all memory back to factory defaults "except" the Life Monitor which has the counters.
Oct 29, 2009 | Muratec F320 Plain Paper LED Fax
Muratec F-300 is not used for faxing, but will not copy either.
Download (FREE) the operators manual from Muratecs web site.
www.muratec.com
Make sure you are in the COPY mode(not FAX.) before trying to make a copy. As the F-300 is a "fax" machine, it will probably be in the fax mode as default.
The downloaded operators manual will help.
Mar 07, 2009 | Muratec F-300 Fax
Toner ran out on Muratec f300
SORRY CAN'T BE DONE. FAX FORWARDING RULES HAVE TO BE IN PLACE "BEFORE" DOCUMENTS ARE RECIEVED INTO MEMORY...THE F-300 ONLY HAD FAX FORWARDING IF IT WAS P.C. CONNECTED AND USING "OFFICE-BRIDGE"
Nov 12, 2008 | Muratec F-300 Fax
Muratec mfx-2500
Try unplugging the power cord for 10 seconds, but you might need a technician to access the SERVICE MODE.
Oct 22, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Muratec F-300
T2.1 means bad phone line.
Do.7 means the STOP was pressed during dialling
DO.2 means the remote machine is busy.
Download manual from Muratecs we site(FREE)
www.muratec.com
Jun 26, 2008 | Muratec F-300 Fax
Muratec F360 Plain Paper Laser.. i need to change the time
What is printed on the top of your received fax's is determined by the sending machine. If the user at the other end does not have name ,date and time programmed into their machine correctly then you will get printed on the top of your received page whatever is in their machine.
Jun 18, 2008 | Muratec F360 Plain Paper Laser Fax
Drum resetting
Press Menu button
Press * (3 times)
Press Menu button
Press * (once)
Press # (once)
Press * (2 times)
Press 77
scroll down to "Drum life monitor clear"
Press Enter (once)
Press Enter (once to confirm delete)
Press Enter (once)
Press Stop or Reset
Dec 04, 2007 | Muratec F-300 Fax
Muratec F-300 Fax Logo
62 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
