Question about Radio Shack Pro-82 Scanner
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
    President:
  • 2,761 Answers
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Posted on Jul 09, 2010
Why won't it stop on scans, but will work on manual entry?
Check to be sure keys are not locked out. Manually select channel 1. Key in the lowest frequency you wish to scan and press ENTER. Manually select channel 2. Key in the next higher frequency you wish to scan and press ENTER. Repeat this routine for all remaining channels. Enable scanning and you should be in business. Don't forget to lock out keys when you are finished.
Jan 12, 2016 | Radio Shack Pro-82 Scanner
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
I am scanning and can't pick up ANY signals how do i program my handheld radio shack 82 200 channels scanner
Hi my name is John. Turn the unit on, press PGM,enter the channel you want to store the frequency in (1-200), press PGM,use the number keys and DELAY/. to enter the frequency you want, including the decimal point. Press ENTER to store the frequency, and your done..Get your frequency,s here www.RadipReference.com ..or www.RadioFreq.com.. Hope this was helpful.....Rate this solution on the four thumbs-up....good luck.. John
Oct 11, 2010 | Radio Shack Pro-82 Scanner
I'm not picking up any local police channels can I program some in? and where can I find the codes for Philadelphia?
Your PRO-82 is fairly simple to program, and you can find detailed instructions in the factory manual which you can download and print, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
FYI, though, many areas have upgraded to trunking systems for their law enforcement communications. If this is the case in your community, you will need to purchase a trunking scanner to listen in.
Bill B
Listening since the 60's
Sep 20, 2010 | Radio Shack Pro-82 Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
I reset my pro 82 scanner now i need to program my scanning codes
Your reset wiped out all programmed frequencies, leaving "000.0000" in each channel. That automatically sets the LOCKOUT icon, but it will clear when you program a frequency into the channel. You can download and print your scanner manual here:
Need the frequencies for your area? Visit:
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
I cleared my scanner pro-82 now how do i program the channels back. the bank1 is blinking and is on channel 1. i do not have any scan codes for local fd/pd in the 78801 area zip code.
For a comprehensive database of active frequencies in your area (they're really NOT codes), visit:
To program known frequencies into your scanner,
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.
Your scanner automatically rounds the entered frequency down to the closest valid frequency. For example, if you enter a frequency of 151.473, your scanner accepts it as 151.470.
Press DELAY/.if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends. The scanner also stores this setting in the channel.
To program the next channel in sequence, press PGM and repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
BillB
Jan 19, 2010 | Radio Shack Pro-82 Scanner
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
Need the manual for your scanner? You can download/print it here:
Nov 05, 2009 | Radio Shack Pro-82 Scanner
Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
359 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
